Question about Whirlpool Ovens
How do i replace the heating element on a fcsm6
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: cooker trips mcb when put
Hi and welcome to FixYa, I am Kelly.
Most likely it is the element. You can prove that the element is bad by disconnecting one wire and reading the terminal to the outside of the element. If you read a short (ZERO Ohms) the element is bad. It is possible for only one terminal to read to the outside case of the element.
You can find replacement elements in the UK on line here:
http://shop.ukwhitegoods.co.uk/Cooker+%252526+Oven+Parts/Whirlpool+Spares.htm
Your replacement oven element (if it is the bad element) will be listed on the label inside the oven door and will look like this: 5320R488 IRCA 240V 2000W RL6 02476
Since you did not metion if it was a cook top or oven element I listed both.
Thanks for choosing FixYa.
Kelly
Posted on Oct 06, 2010
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
My sarena electric oven is not heating up
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Necht element How to Repair Home Appliances
May 17, 2011 | Ovens
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
How do you replace the bottom heating element
Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 09, 2011 | Ovens
Cooker trips mcb when put on a setting that requires heat,would it be element or thermostat,model number is fcsm6
Kelly
Oct 06, 2010 | Whirlpool Ovens
Stainless steel single oven type FCSM6 no.387(electric) not heating stopped in middle of cooking
If the fan is still operating then its the Element that needs replacing..
Dec 21, 2009 | Whirlpool Ovens
Hotpoint EG900X rear round heating element
If the fan is working, but there is no heat from rear element, then the element needs replacing.
Remove inner rear cover of oven, you will see the element there, remove, and replace.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Maytag MEW6527DDS Electric Single Oven
Ovens Logo
323 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
