Question about Epson Stylus C46 InkJet Printer
My epson stylus printer is spoiling
I have replace my new ink cartage. but the problem is my new cartage that i install a while ago is spoiling. now my printer is messy with ink.
what should i do?
  • 3 Answers
There seems to be a problem with ur printer nozzle.......it seems to have broken or sumthin.......the only way u can repair it is by calling the service centre and gettin the piece repaired
Posted on Jun 22, 2008
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
Feb 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Why does my printer not print?
either its out of paper , or the cartage ink is empty or the pronter is not installed correctly. plz indicate what error is it displaying.
Mar 06, 2010 | Epson Stylus C48 InkJet Printer
New ink not printing
If the printer is recognising the cartridge it is probably installed correctly. When you choose Print, check that the magenta image is red and showing a level. If you have run the purge and head cleaning options I would say you have a dud cartridge
Feb 19, 2010 | Epson Stylus C86 InkJet Printer
Epson nx105 has new black cartridge but cyan out. we just want to print black ink but it will not print at all b/c one is low. any suggestions?
you can change the setting in the printer prefaces or do what i did keep an empty color cartage in the color slot and a good black cartage in its slot.
Dec 29, 2009 | Epson Stylus NX105 All-In-One Printer
Epson CX5500 does not see cartage replacements as being full ,so will not print !!
Ok
If your printer cartages are full filled and will not able to print. Please follow the following steps-
1- Uninstall the printer driver and disconnect printer from PC.
2- Download the latest Epson Stylus CX5500 Driver 6.5b Windows 2000/XP  from given web link
    http://down3.driversdown.com/Printer/CX5500_W2K_65bE.zip
3- Install the printer driver from downloaded file and connect printer as setup ask.
4- Now remove the cartages from printer and clean the connecting points & inkjet point by soft cloath.
5- While cleaning the cartage's injet points you will must see the ink on cloath. If ink does not see on cloath may be your cartages are dry. try to clean them by little force.
6- connect the cartages to printer. tyr to print.
It will help you.
Nov 22, 2008 | Office Equipment & Supplies
Can't print with Epson stylus C67
It means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from http://www.ssclg.com/epsone.shtml and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service
manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Nov 06, 2008 | Epson Stylus C67 Photo Printer
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Colors print, but not the black!
that same thing happen to me try to wipe the needle that the ink is on with baby wipes.
Nov 27, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Ink cartridges
didnt see any c46 listed on the manufacturer website. sure you put the right number down?
How old is this printer?
Oct 20, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
