Question about Honeywell Programmable Thermostat Heater
Room temperature is too high and wont let the heater to start
    Problem Solver:
  • 28 Answers
If it is the heater you are trying to start take of the thermostat and touch red to white if the heater then starts you probably have a bad thermostat be sure you make sure the red and white wires are on the proper terminals on the furnace board
Posted on Aug 25, 2010
Fan on gas wall heater shuts off and on every 3 minutes, but the flame is on the entire time.
It always helps to add the model number of the item you want help on. However if it's like the newer units, the fan operates whenever the heater wall has reached a high enough temperature and shuts off when the heater cools off. It is not wired into your thermostat or electrically wired to the heater. It does that with a temperature driven fan switch in a little junction box mounted to the heater. Normally when that box gets hot because the heater is on the fan comes on, when it cools off the fan goes off. The junction box will have an ac cord coming out of it. If this fan switch junction box is not properly mounted it could be getting cooled off when the fan starts and then shuts itself off. After it heats up again it starts the fan. The other possibility is the temperature based fan switch is failing and needs replacement. See link.
http://www.cozyheaters.com/graphics/products/manuals_installation/CDV.pdf
Feb 22, 2015 | Cozy Heating & Cooling
My comford zone heater starts brings room to tempture and stops, but wont start.
does it come on after a few hours? or the next day? all heater have safety fuses in them that sense the temperature near the heating element and will shut down the power to the element to prevent fire. however these things fail some times on the side of caution. It is possible the air flow is not enough or the fuze is faulty
Jul 27, 2014 | Comfort Zone CZ1500WC Infra-Red...
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
My dyson hot fan will not give out air under 24 degrees?
Hi Charlie, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 24 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 24 degrees. The heater will only turn itself on if the temperature drops below 24 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 01, 2013 | Dyson Hot Heater Fan AM04 - Blue
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
2 0f the trhree tiles are not turning bright red.
This heater is a three stage heater...how many tiles are burning is dependent on the setting of the thermostat... (the knob on the top) and the temperature in the room...
If the setting and the temperature are close then the heater will only burn one tile....if the temperature in the room starts to drop then another will light.... and if there is a wide difference then the three will light....
If you have a room that is warm already then you may not be able to get all three to light as the thermostat may not go that high...
If the room is cool and the other two tiles are not lighting then either the thermostat has gone bad or the gas valve is bad.... troubleshooting that is very difficult....it is best to replace the thermostat first and then if that does not work either replace the heater of the gas valve... however the gas valve will cost very nearly as much as a new heater...
heatman101
Nov 07, 2010 | Vanguard International Infra Red - Medium...
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
