Question about Dell Vostro 1510 Laptop
I have yellow lines vertical across my screen sometimes they clear after a while but keep coming back and then wont restart when i shut down what is causing this and can i do anything to rectify?
    Master:
  • 515 Answers
There might be some memory issue so there are not enough memory for graphic device after a while. Otherwise maybe it's the driver of your graphic card. You can press Ctrl+Alt+Del key together and select Task Manager. Then on the process page you can see which process is eating more and more memory gradually. There might be a memory leak issue with that application. Turning that off may improve the performance of your computer. Other try can be to update the driver of your graphic card. You can use Device Manger of Control Panel or the driver disc of the graphic card.
Posted on Aug 24, 2010
Flashing green light and monitor wont start
There are one or two capacitors that open in the power supply, sometimes it will have a bulge at the top, making it easy to spot.
Apr 05, 2012 | Acer Computers & Internet
Hi weve just bought the tv ,its a LG ,its a clear pic but has a very fine vertical line down the middle ,its like a yellow line
Vertical IC is bad or capacitor 100uf 35v in front or behind vertical IC. Call Mats for Parts 1-800-628-1118 But to make sure is Line up and down or straight across TV?
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Blank screen or vertical colored lines on monitor
sounds like a graphics card failing
is it on board graphics ?
if so try a graphics card in there see if that helps it
also if you could borrow a monitor and see if that helps
its either one or the other and is a process of elimination
Mar 24, 2008 | Gateway Profile 4 All In One (MPN...
Glitchy power
Clearly your TV is shutting down due to a problem. Based on your description, it's hard to tell if you have a vertical or convergence failure. What do you mean by "waving" line ?
Feb 01, 2008 | Samsung HCM422W 42" Rear Projection...
Picture problems
If the line goes across the screen you have a loose solder joint on the vertical output IC. I've seen this happen many times in Zeniths and a lot of other sets. If the IC is not loose then there is a loose solder joint somewhere else in the vertical circuit. These IC's are 10 - 13 pin chips that operate the vertical deflection on your set. I feel like a drop of solder in the right place will fix it! Stargazer
Apr 10, 2007 | Zenith C27A24T 27" TV
27" flat screen
The main cause of this problem is cracked solder joints on the vertical output IC. Re-flowing the solder should take care of it. Sometimes a capacitor (normally against the heat sink containing the vertical output) will cause this, but, it usually has a different symptom. The price of repair will normally run, depending on where you live, $100.00 to $130.00. It's a small job and is done quickly. Hope this helps.
Mar 17, 2007 | Toshiba 27AF41 27" TV
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Dell Vostro 1510 Laptop Logo
138 people viewed this question
Alun Cox
