When i put ir2230 power on , after few seconds it give an error (right door open)
  • 1,219 Answers
these means thatyou need to apply more strenght on right door, to be exact on marking with hand illustrated beneath the open button.
Hope that helps!
Posted on Aug 24, 2010
Where are fixed toner sensor in iR2230 machine, give me image or video
Open the front door and side door and pull out the developing unit. Just under the it is the toner sensor unit.
Oct 10, 2014 | Canon Super G3 Fax Board for IR2230 Copier...
Photocopy IR2230 error code 0001/0002
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Jun 02, 2014 | Canon imageRUNNER 2200
Canon printer ir2230 is displaying error E000805-0000 canon
fixing unit fans are not move open door & move the fan
Mar 19, 2013 | Canon IMAGERUNNER 2230 Copier
My 2000 ford explorer is having issues with the door alarm and interior lights remaining on even though the door is shut.Any advice is great.Cheers.
Go sit in your truck and close all the doors. Light stays on right? Put your key in the ignition. Does the chime start going off when you put the key in? If so, door switch or the GEM thinks a door is open.
To find out which door... Leave the key in the ingntion. Turn to the on position. Even with doors closed, chime sounds once after a few seconds and door ajar light comes on and stays on right? Open each door one by one. The chime should sound each time you open a door. When you find the door that doesn't make the chime sound when you open it, that is the problem. (Don't forget to try the rear hatch and the hatch glass also!) To determine if the switch is bad or if the GEM is having a problem thinking the door is open, just unplug the suspected switch, close all the doors, and see if the problem stops. (don't forget to wait a second to give the lights time to go off) If unplugging the switch solves it, the replace it. If it doesn't, Ford can check your GEM to see if it is the problem.
I hope this helps
Dec 02, 2010 | Ford Explorer Cars & Trucks
Disc door won't open. I have tried to remove the battery and power source but the door still isn't opening
I have heard of this only a few months ago, it was the way the camera door can get fouled up by a wonky disk not stopping at the right place.
Try to shoot a few seconds of extra movie, then try to open the door again.
If that does not help press the reset button for 30 seconds to open the door (see handbook) on doing that.
May 15, 2010 | Canon DC40 DVD Camcorder
I accidently locked the oven door and I can't get it unlocked. What do I do?
Disconnect power for a few minutes then retry.If this doesnt work put it into self clean again start then after a few seconds hit cancel. Give it a few minutes and the door should unlock.
Apr 02, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FES367ABC oven gives f9 error, door lock light is blinking, door not locked. how do i fix
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Frigidaire FES367 Electric Kitchen Range
My Sharp copier gives a CH error when turned on.
One of your doors is not shut all the away or dv unit is not installed.
Feb 12, 2009 | Sharp AL 1631 Copier
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
k24674
jasbo
jasbo
