Question about Boating
There is water in my oil i dont no what to check first i have a 3.0 mercriuser inboard/outboad i put in water temp started riseing so i shut off someone told me my water impeller in leg wasnt working so i checked and its true . well now i have water in my oil and was wondering how it got in there if there was no water coming up the leg to the engine. the oil was clean when i put it in
    Problem Solver:
  • 19 Answers
You will need to do 2 things first, A compression test to check the it hasn't blown a head gasket.
Then a pressure test on the cooling system (BUT) leave the spark plugs out when you are doing this.
If you have trouble holding pressure in the cooling system , stand by and keep pumping and wait to see water coming up out of a plug hole.
Hope it turns out well for you. Good Luck
Posted on Aug 26, 2010
1996 mercury 60 horse 3 cylinder 2 stroke
problem in the idle settings of the carby
could be rubber bits from deteriorating rubber hoses /water in the circuits but it needs attention from accredited mercury service centers
Apr 25, 2017 | Mercury Boating
My engine overheating problem is in my 2000 land rover. The fan is running and the electric fan comes on at correct engine temperature. After start up the engine runs normal the temp gage rises slowly to...
the usual suspects are:
stuck shut thermostat
clogged raiator
dead water pump
low coolant level
it's sunday, rovers don't work on sunday.
Then again, maybe its wednesday, rovers take half a day then. 25322555-21syibu3fgwpdxocjnkpw0ib-5-0.jpg
Dec 15, 2014 | Cars & Trucks
Have a 1998 Chrysler Concorde with 134,000 miles. About 2 months ago it started stalling intermitently. Would stall and I could restart immediately. Now it stalls once every trip at a certain engine temp....
your car problem is overheating, some car model like yours is designed to shut-down engine when engine temp. rise so as to avoid frying the engine. your engine overheating problem is attributed by one of these factors:
1. check or refill radiator water if less
2.check radiator cooling fan operation-if damaged pls. change or check the electrical system.
3. damage/ worn water pump-if damage pls. change the water pump.
4. check for any coolant leak somewhere the coolant line-pls. rectify the leak.
5.worn coolant reservoir cap- change if damaged.
6. clogged radiator-if clogged pls. change it.
7. damaged thermostat valve.
May 06, 2010 | 1998 Chrysler Concorde
I have a goodman gmp125-4. The heater comes on the furnace fires up with all the burners on and it shuts off after maybe 5-6 minutes and then the module light blinks 4 times. Are there any solutions for...
You have a serious problem. That is the primary limit overload in the heat exchanger. Either your gas pressure is too high...checked with a manometer should be 3.5" w.c. for Natural gas and 10" w.c. for LP, or your air speed is too slow. If you have a restriction in the duct, even dirty filter, your fan speed will slow causing the temp rise from return to supply air to rise. The unit data plate has the temp rise range on it...for that unit it is probably 45-75 or close thereabouts. you should check the air temps a couple of feet from the unit on the return and supply duct. If the data plate shows 75, or whatever, your actual temp rise should be 10 degrees below the max on the data plate or in that case 65 higher. This unit has a three speed motor, if Black from the motor is not on the heat terminal of the control board,start there. With power off, put the black wire on the heat stake on on the board. If it is already on the cool spade, you can make a jumper and use that same speed for both heat and cooling. After this is done, recheck the temp rise on the air and see if you get about 10 below the max on that temp rise data.
If the temp rise looks good, be very careful in doing this; with power off, remove the primary limit, which is the one going into the exchanger, and either temporarily jump out those two wires or just set it aside still hooked up so the wires dont touch anything and with a temp probe or thermometer stick in the hole where the limit goes, start the unit and check the temp at that spot. That limit is 210 degrees. If it is rising higher than that and you are sure the temp rise is good, you probably have crack in the heat exchanger shooting hot air in that area close to the limit.
Hope that helps.
Jan 05, 2010 | Goodman GDS80904BNA Open Flame Heater
My landroverdiscovery 2000 shuts off after running for about 10 to 15 minutes then wont restart until engine cools done mechanic says it has a headblown gasket but truck is not overheating
hi, to me it sounds like the oxygen sensor needs replacing if it runs fine when cold then plays up when it reaches temp then this would be the sensor as the sensor only starts working when it reaches running temp
Check the oil for signs of water if its like chocolate ice cream then this indicates head gasket failure
check water for signs of oil this would look lik mayonaise floating on top in the water filler bottle.
Whilst its running check the water level doesnt rise if it does then head gasket gone if it remains the same then you should be ok.
When it gets to temp and cuts off remove the water filler cap and then try starting if it starts then this is head gasket failure
If none of those show up then i would go with the oxygen sensor replacement.
Let me know how you get on or if you need further assistance ok
Nov 24, 2009 | Land Rover Discovery Cars & Trucks
I have a serious overheating issue. As the vehicle idles the temp starts to rise if you bring up the revs the temp will fall a bit. As your driving it rises at every stop light or traffic line up. We...
With what you describe the problem to be I would have the radiator flow checked. Sounds like it may be clogged if not the pump is probably bad. The head gasket should be o-kay due to no loss of fluid or smoke out the tailpipe. Do theses checks and you should find your problem.
Oct 01, 2009 | 2002 Oldsmobile Silhouette
Temperature gauge is rising to high
when you remove your oil cap is there foamy **** on the inside of the cap, if so you may have a crack in one of your gasket
Jul 20, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
