Question about LG 42LC2D 42 in. LCD HDTV
While watching a tv show, the picture split/broke vertically. Literally, the first 4 inches of the left side is flanked by four inches of dark gray (with a light gray band in the middle), then the first 4 inches of picture are repeated overlapping the last half of the screen (which is playing as normal). It is the tv, since changing to other inputs yields this same phenomena. I've tried unplugging the main cable for 15 seconds, in case it was an odd issue there, but that didn't work. Any help would be nice
  • drgonfire1 Aug 24, 2010
    So basically I need to get someone to fix this problem because the hardware's basically died on me. That's.... not the most ideal situation...
  • LG Master
  • 5,138 Answers
On Power supply board ,Look for Bad Capacitors they will be vented,swollen or Puffed up on Top 1000uf 16v 220uf 10v 3300uf 10v 330uf 10v. Also the Main Board can cause this its the board that has where you connect cable and AV jacks on it,I have just resolder these boards and everything went back to working, But thats not always the problem.
Try Google then go to Encompass Parts Distrbution and type in your model number for listing of Parts and Prices
Posted on Aug 24, 2010
  • ladywinn
    ladywinn Aug 24, 2010
    You could also have problem in the Display Panel, and if you are not able to solder or remove bad componets then you do need to take it in for repair. Go to Ebay and Look under Electronics and type in your model number for listings of TVs/Parts.
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Dark vertical line going from top to bottom on the lcd screen.
http://uk.youtube.com/watch?v=qBpg77ZzFFk
watch this it will tell you how to fix it.
Jan 08, 2009 | Televison & Video
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Dark vertical shadows
No,you can't. This is very common. I bought a new tv and i noticed right away that it had the problem you are mentioning. I took it back for an exchange and the next tv did not have this problem...until a year later. Now,of course it does have this problem,but it is out of warranty.
I think they make televisions very poorly today.
Apr 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dark vertical line(s) on Lcd tv
Most likely it's the LCD panel failure. You can replace the panel if you can find a spare part. But the new panel may cost you as much as to buy a new tv. Hope that will help you.
Jan 27, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
117 people viewed this question
Computer Repairing
Computer Repairing
