Question about Intex Pool & Spa
5 days ago the water in my pool went green. I have tried everything, I have adjusted the ph level and clorine, I have added copper sulphate, and anti algae. I have also tried a shock treatment, and have had the pump on for hours everyday. I have also changed and cleaned filter every 4 hours, please help
  • 366 Answers
You may have an underlying problem like phosphates or damage filter cartridges. Have the water tested for phosphates and inspect the filter cartridge(s) for any damage around the ends where it makes the seal to the filter body. Stay away from copper sulfate as this can lead to staining. Try using a polyquat60 type of algaecide or a colloidal silver type. Algae particles are microscopic, if the water turned green and not just the walls, chances are you may have to drain it and start again. There are some products like fiberclear that can increase the filter efficiency temporarily to help clear it up. You should be able to find it at your local pool supply store.
Posted on Aug 26, 2010
How can you decrease copper levels?
copper levels have to be lowered by delution (adding more water)
your daughters hair rinse with lrmon juice the reason this probably happened your PH and alkalinity are both probably low PH should be between 7.2 and 7.6 alkalinity shouls be between 80 and 120 if un aware of pool chemistry take water to a professional
Jul 14, 2014 | Intex Automatic Salt Water System for ...
High copper, High alkalinity, No chlorine & salty water
call in a pool expert to help you set up the system properly and to check the chlorinator
from your statement you are making things worse by not fixing the problem
Mar 18, 2017 | Intex Automatic Salt Water System for ...
What can I do for cloudy greenish water
make the priority fixing the water with an overdose of chlorine making sure to not use the pool for swimming while doing this, after the green goes, and you will know when you have put enough chlorine in when it clears up, then re adjust your pH level. after the level is correct, use the pool as normal .
Jun 10, 2013 | INTEX Sand Filter Pump
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
The bottom of my pool is a greenish color. What can I do about that?
Easy turn the pump on and into the skimmer add some copper sulphate ,depending on sixe but about a cupfull should do it ,then add some systemic weed killer where the water jet is to circulate it quickly,Yes i know its not in the manual but? then do a water test for the PH value and if its way too high which i suspect then add some acid look on container for the instructions as this stuff can vary in strengh,Now i use hydrocloric acid which i buy in 5 litre containers from the supermarket here in spain ,its for cleaning floors here and use this as that acid is expensive from the pool shop ,If the ph is too high it will go green in a day in full sun ,Now as the copper sulphate dissolves in the skimmer it will come out the other end and leave a dust cloud on the floor near the jets so dont panic use the pool hover thingy and leave the setting on filter and **** it back up through the filter and a few hours later you will have some more but by the third time it will have dissolved completely ,Now turn pump off for 24 hrs and allow the algae to settle to the bottom but it will be so fine it will pass through the filter and come out the jets again so put pool on waste when you clean the bottom again and then it will be clean ,keep a check on the PH regular though as the more the kids use the pool the quicker the PH will rise again so keep a eye on it at least twice a week ,You do not need lots of chlorine i use about 2 pastels a week in the summer at the most once you have added the copper sulphate .
Apr 11, 2012 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
Fiber glass pool, PH 6.8, on adding chlorine the water turns see through green for one day the clears to blue?
I assume you have a heater...the green is from the high copper content in your water reacting with the chlorine. Get your pH up as soon as possible and get a copper reading on the water. Assuming it is high you will need a metal-out product from a local pool store. We prefer the Natural Chemistry line of products in our service company.
John
Oct 15, 2010 | Pool & Spa
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
My water turns green when we shock it I have drained twice now Please help!!!
start with testing your chlorine and ph add liquid shock and conditioner to water dont use algecide you have to get clorine to open up this is critical ph clorine and conditioner you should get a good clorine reading or you have to add more shock
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Green water
Chlorine generators raise your pH over time. You will always have to monitor and, on occassion, adjust your pH down using acid. Your water being out of balance likely lead to the green water condition.
Check your alkalinity first and adjust it if needed. Once it is stable, adjust pH using acid, then get your pool shocked to kill off the algae. You made need an algacide too but save that for last and only if required.
Pool & Spa Logo
62 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
