Question about Mitsui Advanced Media (MI-DVDR4-7BNL)
I have auto tuned my Matsui (m16ud709) connected to my Sky Plus box. However when I turn it on in the morning I get the "First time Installation" screen appea ragain and have to re-install. I have put it on stand by several times during the day and it comes on fine, but not if its on stand by all night.
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
How can i tune all my sky channels to my dvd/vcr combo box
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo.
Make sure you are scanning them into the box not the combo.
Jun 14, 2012 | Daewoo Televison & Video
My 32LG3000 is flashing 'Not Programmed' Have done auto tuning option and get message 'can't find any valid channel-Check antennae and run auto tune again' TV is connected to a sky...
Try changing the source from the tuner, which is not programmed, to "video 1" or whatever the input for your Sky HD Box is plugged into. I would suppose as soon as you change the input method to not be your tuner, this error will go away.
May 06, 2011 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Electronics - Others Logo
89 people viewed this question
Top Mitsui Advanced Media Electronics - Others Experts
Are you a Mitsui Advanced Media Electronics - Other Expert? Answer questions, earn points and help others
