Question about Behringer Audio Players & Recorders
Behringer eurodesk mx8000 schematic:- Was working fine for live show. 3 lines/3 microphones, only 1 in phantom - suddenly all green signal lights on but not output. Turned power supply off then on and it worked...5 mins and then same problem again. Now, without anything connected to the console, the channels 2, 4, 10, 15 and 19 have a green light...without anything connected. Please provide the full schematics for our electronic experts, who can investigate. (Purchased from UK, based now in Greece) Regards Heather
SOURCE: iPOD SAYS "PLEASE CONNECT POWER DEVICE" BUT IT IS PLUGGED IN
try updateing your itunes or letting ur ipod charge
Posted on Feb 25, 2009
hardrocko
  • 1476 Answers
SOURCE: When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Posted on Jun 22, 2006
ThaMp3Doctor
  • 8596 Answers
SOURCE: YP-U3JZW/XET frozen
First, make sure the hold switch is off
Then, Push the hold switch in the direction of
the arrow.
Press and briefly hold the user and play/power
buttons at the same time to
reset the system.
Then, upgrade the firmware - b/c plugging it into a Linux system cause the DB to become corrupt
Finally, go to the Linux forums, b/c this player was definitely NOT designed for Linux, and you will never get an answer in this section
Posted on Jul 06, 2008
  • 3 Answers
SOURCE: COBY TFDVD5605 Portable DVD Player repair tips
all potable dvd player work on 9V through cig lighter in your car adopters comes in three diffrent sizes.
Posted on Jul 20, 2008
Benimur
  • 6966 Answers
SOURCE: no output from power supply
I am assuming that you are very familiar with electronic circuitry and components, use of a DVM and a soldering iron. In the absence of a schematic diagram, and since you have perform initial voltage checks, perhaps you can wing it. Your "brick" will have to follow the basic design of an SMPS (switch mode power supply). Simply stated,an SMPS is an AC to DC to high freq AC then to lo V DC converter. Per your post, you have checked that there is DC (B+) from the AC mains, then what is needed is to check if there is oscillation to produce the high freq AC. Often design calls for an optical coupler, a small rectangular looking component with four pins, two at each end. This is nothing more than a LED and a Light Dependent transistor. Its function is to switch/trigger on the oscillation (and therefore start the SMPS producing the lo B+s).
Again, since there is no readily available schematic diagram, might I suggest that you post back the part numbers of the ICs and transistors. What we can do is pull out their spec/data sheets and/or application diagrams. Such would give us a general idea of the working voltages at what pins and what each component is supposed to do. Example, let us say your power supply uses a 817A/0635 opti coupler and/or an SG5841DZ controller IC, then we can search for them as initially described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
Input gain pots not working the others ok
unfortunatly this would not be a user servicable problem and would need to go to the shop. Here is a link to Behringer contact page. Scroll down to the Locate a service center link. BEHRINGER Limited Warranty
Feb 26, 2015 | Behringer MX9000 EURODESK 24 Channel In...
My aim is to be able to drive a sine wave generator directly from vocals through a microphone. The set up I have planned so far goes - microphone (Behringer B-1) - Power supply (Behringer PS400) - min
  1. Yes, you need the PS400 with the B-1. Alternatively, you can connect the mic to a mixer with built-in phantom power.
  2. The PS400 shouldn't go directly to to the TA2020 because the power supply is providing a mic-level signal and the amp is looking for a line-level signal. Either add a mic preamp after the power supply, or if a mixer is used, that output can be fed to the amp.
  3. Cabling will depend on what you ultimately choose to do. But, you'll at least need a mic cable to go from the B-1 to the power supply or a mixer.
Oct 30, 2014 | Behringer b-1 single-diaphragm studio...
I need a schematics power supply for MX9000EURODESK
Check out elektrotanya.com you can get 2 circuits per day or pass the electronics test for more. Good Luck!
Oct 01, 2014 | Behringer MX9000 EURODESK 24 Channel In...
My behringer c1u doesn't have a blue light. apparently it has no phantom power, and i just bought it. is it the usb ports? if so, please explain.
Answer from official Behringer support:
The green LED is fine. The newer units have green LEDs.
Please download and install asio 4 all from:
http://www.behringer.com/EN/Products/C-1U.aspx
We hope that we have been able to help you with this information.
Feb 12, 2011 | Behringer C1U Microphone
The c-1 mic is not working.The red light will not turn on when i put it into my laptop
With the C-1 it does require phantom power to work. On the board your using make sure the +48(phantom power) button is pressed in and it should be golden.
If it's the C-1U, the drivers must be installed first. http://www.behringer.com/EN/Products/C-1U.aspx
Good Luck, Cody J.
Dec 16, 2010 | Behringer C-1 Microphone
Wire Colour coding for Behringer C1 Microphone
It is likely that the brown goes to pin 1 (ground/shield phantom -) as well as the black.
Red is likely to go to pin 2 (across from 1)(signal +)
and the orange to pin 3 (signal -)
Apr 15, 2010 | Behringer C-1 Microphone
No signal to Digital Recoder
If the a95fp is a transformer that goes from xlr to 1/4inch, it will not pass phantom power. Your mic needs phantom power to operate.
Apr 01, 2010 | Behringer B-1 Professional Microphone
What do I need to provide phantom power to Shure Beta 87A microphone? All I have is a fender acoustasonic combo amp...
You will need a Shure PS1A phantom power supply if you want to use the manufacturers recommended part although any phantom power supply that puts out 11 to 52 volts D.C. positive at both pins 2 and 3 with a current drain of 1 to 1.2ma should work. Behringer makes good affordable ones. Check out this link:http://www.behringer.com/EN/Products/PS400.aspx Hope this helps.
Nov 24, 2009 | Shure Beta 87A Professional Microphone
Behringer B-1 Will Not Pick Up Anything
The microphone needs a phantom power supply to work. In your case you need a 48volt phantom power supply. Some mixers have this feature built in.The Micropower PS400 by Behringer would probably be a good choice.
Apr 19, 2009 | Behringer B-1 Professional Microphone
590 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
