Question about Microsoft Windows XP Professional
Taskmanger problem m running win XP professional sp3 on 32 bit i cannot get taskmanager.. i cannot regedit.exe my USB shows virus but cannot be healed by AVG there is folder that keeps duplicating itself even after deletion i have unchecked system restore .. & now also turned on windows firewall now i realised i could not even see folder options, so that i cud seehidden file like autorun.inf create new autorun.inf & replaceoriginal as read me file i m not a programmer but learning to fix things in my PC please help
  • jackpot2013 May 11, 2008
    i had installed sp3 before this problem occurred .. i will try switching back to sp2 .. but m doubtful of how this will help clear virus..
    Problem Solver:
  • 6 Answers
This does sound like a virus to me. If you can't get it removed with AVG, try going on the internet to TrendMicro's Housecall. Housecall will scan your computer for viruses and remove them, and it is free. There are other free virus scanners on the web that you could also use.
FYI - The purpose of turning off System Restore is so that the virus scanner can find viruses in these files also. Once the virus has been found and deleted, remember to turn System Restore back on. It is one of the most useful repair tools that Windows has, but will only have a restore point that you can turn your computer back to if it is turned on.
Posted on May 05, 2008
    Genius:
  • 3,422 Answers
HI,
Did you install sp3 just now.Or were you using it before this problem occured.Let me tell you one thing the sp3 is not yet ready fully most of the people are facing huge problems with it.I suggest you to switch back to sp2.Or you can try reinstalling ur sp3 once again.
Goodluck..
Remove w32/sality
Infected files can be healed by using of Win32/Sality removal tool. Download the following three files ( rmsality.exe, rmsality.nt, rmsality.dos) and run the rmsality.exe file. 1)rmsality.exe 2)rmsality.nt 3)rmsality.dos
Note:
Successful running of the remover requires administrator rights. After the healing process please run the antivirus to make sure your computer is virus-free.
good luck!
Jun 23, 2010 | Microsoft Windows XP Professional SP2
WindowsXP-KB835935-SP2-ENU-exe is not a valid Win32 application
Hi, It seems that you have downloaded the wrong version of the software. However, to know which bit version of you are using, perform the below steps: Method 1 1. Click Start, click Run, type sysdm.cpl, and then click OK. 2. Click the General tab. The operating system appears as follows:? For a 64-bit version operating system: Microsoft Windows XP Professional x64 Edition Version < Year> appears under System. ? For a 32-bit version operating system: Microsoft Windows XP Professional Version< Year> appears under System. Method 2 1. Click Start, click Run, type winmsd.exe, and then click OK. 2. In the details pane, locate Processor under Item. Note the value. ? If the value that corresponds to Processor starts with x86, the computer is running a 32-bit version of the Windows operating system. ? If the value that corresponds to Processor starts with ia64 or AMD64, the computer is running a 64-bit version of the Windows operating system. If you have downloaded the correct software, then perform the below step: Right click on the file WindowsXP-KB835935-SP2-ENU-exe and select properties and select properties. Click on Compatibility tab and check "Run this programs in compatibility mode" option and in the drop down menu select Windows NT 4.0 (Service Pack 5). Then click apply & Ok. Then restart the computer to make the changes effective. Hope this should resolve the issue. With Regards Mike.
Oct 02, 2009 | Microsoft Windows XP Home Edition
Taskmanager disabled by your administrator
Click on start then run
Type gpedit.msc then ok
Click + on administrative templates
Click + on system
Click on CTRL ALT DEL options
over to the right double click on remove task manager
Click on disabled then apply then ok
You will now have back taskmanager
This is normaly caused by malware you should if you havent already run an anti malware scan.
Malware Bytes is an excelent example of a scanner and is located here: www.malwarebytes.org get the free trial version its great.
May 07, 2009 | Microsoft Windows XP Professional With...
My taskmanager has been disabled by virus
Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Method 2 Download and run this REG fix and double-click it.
Method 3
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 4: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
Feb 12, 2009 | Computers & Internet
Taskmanager
use virus online scanner. you have viruses
May 05, 2008 | Microsoft Windows XP Professional
Taskmanager
If you have access to a clean computer with a burner, then download Hirens Boot Disc.
The download is only around 80-90 meg and can be burnt onto a cd or dvd.
Download HERE.
Burn that program to cd and put it into the infected PC. Start the computer up and boot from the CD instead of the hard drive.
There are anti virus utilities on there that run in Dos mode without ever loading anything from your hard drive.
My taskmanager gone
check this... click start, run, regedit, check the path from this link.
if this doesn't fix it then, we'll have to go deeper. just fixed on of these 2 days ago.
http://www.windowsnetworking.com/nt/registry/rtips91.shtml
Apr 09, 2008 | Microsoft Windows XP Professional With...
Taskmanager & regedit
When you press Ctrl + alt +delete, the task manager does not appear? Try right clicking on your desktop tool bar and clicking task manager: For regedit click Start > run and type regedit
Mar 26, 2008 | Microsoft Windows XP Professional for PC
Virus from ym
try using bitdefender anti virus. it removes most of the viruses with no strings attached
Nov 21, 2007 | Microsoft Windows XP Professional for PC
I cannot get Taskmanager Option
hi try this if ur adminstrator
    Close Regedit.exe
gizmo 1 (A)
Oct 17, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
