Question about Technics Audio Players & Recorders
Motor makes a loud, humming noise, turntable works anyways
  • peter_keel Aug 24, 2010
    The turntable is old infact. Would some lubrication help may be? But where exactly?
    President:
  • 4,070 Answers
Hi! Usually, we put oil on the motor to get rid of the noise. Try it and may work for you. Hope this helps and thank you for using FixYa!
Posted on Aug 24, 2010
    Guru:
  • 256 Answers
I gather that the turntable is fairly old. The bearings on the motor might be going, so I sugest play it until it stops dead, and then know for sure which part to replace. Hope this helps
  • 1 more comment
  • Morne Olivier Aug 24, 2010
    If you lift the felt off the platter section, you will notice two fairly large holes in the platter itself. Before lifting the platter off the base, try getting a silicone based spray lubricant with a long tube (straw like)on the nozzle. Move the platter around until you see the spindle motor, (to the side of one of the holes). Spray a little lubricant on the spindle. If you cant reach the spindle from that angle, using your thumb and fore finger, pull upwards to lift the platter of the base. NB Please take note that once you perform this, you will have to reroute the drive belt! Use some silicone lubricant and spray a little onto the spindle motor, driving the platter. Now, to replace the belt: lay the belt out into the base, around the spindle motor. Replace the platter and reroute the belt onto the inside rim of the platter. It is a bit tricky but you should get it back on by the second try. Hope this helps
    NB Please try not to get any of the lubricant on the spindle head or the drive belt as your turntable will start slipping!
    The lubricating did wonders! No more noise. Thanks.
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Made loud noise and wont stream
follow this test and fix it. God bless you
Oct 24, 2013 | Wolfgang Puck Bistro 1400-Watt 3-Tier...
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
My record player works but makes an aweful noise like the turntable in rubbing up against somethin
If it is a loud hum besure there is a ground wire connected to the back of the receiver from the turntable.
Apr 24, 2009 | Audio Players & Recorders
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Have a B&O RX-2 with mcc4 and loud hum
Possibly check the wires on the cartridge, make sure none of them are touching and are not bent to badly, are all the connections tight? some cartridges require plastic sleeves over the connections, this insure they don't touch and
avoids resistances between them. Also some cartridges are not compatible with certain model turn tables.Is it universal? Also you my need a mixer most turntables don't work with amps alone. Mine don't. Usually most models you attach the ground wire to the mixer. A mixer boosts table power and take stress off the amp. Hope this helped! good luck!
Jan 31, 2008 | Sony PS-LX350H Turntable
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
88 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
