Question about JVC KD-S5050 CD Player
Remote wire Is the REMOTE wire the blue wire like on most brands ?
  • 3 Answers
Assuming your talking about a JVC KD-S5050 you want the blue wire with the white line on it for the antenna up/down function.
Posted on Jun 26, 2010
  • 78 Answers
I don't know which wire is for the remote, but blue is usually for the antenna up/down function.
Posted on May 05, 2008
I need to know what color is remote wire in the stereo
not sure what brand or model your using but every time i've installed a car stereo the remote wire has always been the same. (to be clear i'm not saying they're all going to be the same) but ive worked with multiple brands before and the remote wire in everyone of those was always solid blue! hope this helps.
Apr 24, 2015 | Cars & Trucks
Brand code for Blue diamond
I had to get a Rev 10 version of the Sky remote as those codes did not work and I entered in the CORRECT Blue diamond code which is 2586. this worked perfectly for me. other codes for blue diamond are: 2134, 2454, 3493, or 3500.
Sep 25, 2014 | Televison & Video
Remote code for sony blue ray player
There is no set-up code to any brand blue-ray player with this remote control.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 21, 2014 | RCA Televison & Video
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Amplifier remote start wire
There are dedicated terminals / connection points for "remote" input and output on both the amplifier and head unit. This info usually figures prominently in the manuals of both products. Without knowing the which brand and model head unit and amplifier you have, the info may be incorrect. In the past, many head units made use of Blue or Blue/ White for a remote signal. It was used to control an external amp or automatic antenna. An example is the image below of the wiring of a Kenwood KDC-3011 head unit:
Check your manuals (or Google model numbers) to find yours.
Dec 01, 2011 | Kenwood Car Audio & Video
I do not know which wire is my remote wire to hook up a amplifier
You haven't mentioned the brand of your radio, so it is hard to tell you. But in most cases, blue with white strip is commonly used for remote to hook up amps. If possible look for ignition wire in you radio, which is mostly red, connect together and hook up.
Mar 04, 2011 | Car Audio & Video
What is the rem termial on a crunch amp
the terminal marked "rem" on most amplifiers (if not all) is for the remote signal.
The remote signal is a low current signal that tells the amp that the carstereo is "ON", this "activates" the Amplifier and turns it off again when the carstereo is turned off, if the amplifier stayed on all the time it would drain your battery while the car is off
so, anyway if your carstereo is enabled to work with an amplifier it should have one wire marked "remote" some brands use a blue wire for such purpose.
If you cant find wich one is the remote wire or you are using an original euipement manufacturer (OEM) carstereo, you need a test licght to check wich wire puts out current when the carstereo is on and switches it off when you turn off the unit, that should be the remote wire.
it is advisable to use that signal to operate a relay instead of directly using the remote wire on the amp, but its more of a security/professional install kind of motive.. so if you understand relays go for it, if not, go ahead and connect the remote to the amp... NOTE: THIS WAY IF YOU SHORT THE REMOTE WIRE YOU RISK DAMAGING THE CONNECTION OF THE REMOTE INSIDE THE HEAD UNIT...
PS: i use carstereo, unit and Head unit as synonyms because english isnt my native language and here we just call them "stereos" but thats just wrong
Jun 23, 2009 | Kicker KX600.1 Car Audio Amplifier
Remote wire color?
the remote wire will be a solid blue this is always the color no matter what deck you have
Apr 19, 2009 | Alpine CDA-7892 CD Player
Wiring up a sub and amp
The acc means a power on connection when you turn on the key..On your amp you'll see a blue wire or a connection that says remote..Then find a connection on the car that when the key is turn on or when the radio turns on it turns your amp on for you threw that wire..Hope this helps you...
Apr 04, 2009 | Car Audio & Video
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
JVC KD-S5050 CD Player Logo
127 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
