Hello i have a techwood wd 1047 washing machine with no instruction manual. I would like to know out of the 9 different cycle options for the cotton material uses the least water or is the most economical in water usage? I assume it is the option 5 as it says eco next to it. When i choose this option though the washing cycle takes longer then 1 hour close to 1.5 hours. Is this normal?
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 90 Answers
SOURCE: Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Posted on Feb 10, 2008
  • 351 Answers
SOURCE: Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
Posted on Apr 03, 2008
SOURCE: beko AA class washing machine 1000rpm WMA 510W
If you search on the Beko website, you can download manuals for their machines (including the 510W).
Posted on Apr 24, 2008
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Posted on Aug 04, 2009
How to return temp set to programme norm
PDF]Washing Machine - Samsung
www.samsung.com/us/pdf/wf218_manual.pdf
Samsung Electronicsto read this manual to take full advantage of your Washer's many benefits and ...Warnings and Important Safety Instructions in this manual do not cover all possible conditions and ..... per hose and install each fill hose to the water valve. ... Press the button repeatedly to cycle through the different water temperature options.
[PDF]User Manual - Indesit
Jan 16, 2016 | Washing Machines
Hello, I was given a CANDY Smart washing machine CTG 856 but there is no instruction manual. I searched for the manual online but there was none available. Do you know where else can I find one? the main...
hi
the manual for you washing machine is not yet available online but you can request for it to be sent to your mailing address and you will get it shortly.
the link is
http://www.candy.it/libretti/libretto.cfm?lang=2&country=7&brand=candy
Aug 27, 2011 | Candy Washing Machines
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
My Mom is 90 yrs old and lost her machine instructions. The model is front loader WD 80250 NP ( now 4 years old). Can I down load the manual? My other question is: On the Cotton cycle does the programme...
Home Depot Sales Associate-
You can find the manual for the product here.
http://www.lg.com/levant_en/support/product/support-product-profile.jsp?customerModelCode=WD-80250NP&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-80250NP&initialTab=documents&targetPage=support-product-profile
The unit is designed to only operate properly with a hot and cold faucet connection. The exception is if it has a cold wash cycle and you are operating it on such. (that model should not) Also, once you set the cycle, you should not manually interrupt the cycle to change to the desired portion of the cycle. Front load wash units take longer to run due to the usage of less water. They also need high efficiency detergents to operate properly and cannot be overfilled with detergent.
Your description of a soap lather sounds like you are using the wrong detergent and in the wrong quantity. HE only.
Mar 20, 2011 | LG Washing Machines
Would like a owners manual for my WD-1290RD can't seem to find one on the net anywhere.
Here's a link to a site with your manual, it's free. If you need a different manual for a different country, just use the search bar on the site to locate one.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1290RD-_E
Hope this helps, and best regards!
Jul 31, 2009 | LG Washing Machines
Instruction manual
Option B is the standard option for whites and colors and is approx 125 mins long. Option A adds a 25 min soak. Option C/D is the short cycle at 70 mins. I haven't figured out how to program an extra rinse yet.
Apr 18, 2009 | Washing Machines
MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
May 02, 2008 | Washing Machines
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
