Hoover 2307L Heavy duty washing machine. not spinning properly. Any solutions?
catriver
  • 878 Answers
SOURCE: Kenmore washing machine
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
Posted on May 21, 2006
  • 351 Answers
SOURCE: hoover 800 heavy duty washing machine
the clicking sound could be the brake arm worn its white and in the middle near the gear box,the reset is for water only.the outlet pump is at the back where the drain hose comes out.the filter is in the middle of the agitator just pull it out.check the belt isnt loose.
Posted on Mar 02, 2008
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
SOURCE: Instruction manual for Whirlpool Heavy Duty Series 8 Machine
I have the manual if you need help, but the mechine is simple to use, just put the fabric conditioner in the top of the thing in the middle (inside the machine) the bleach dispenser is is just for bleach. You just get a cup of washing poweder and throw it in!
Posted on Dec 26, 2009
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Sep 13, 2014 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
Feb 25, 2009 | Kenmore Washing Machines
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
