Question about Intel D946GZIS Motherboard
Yedterday i re assembled my pc i have a probleam with internal connection like (front panel usb,restart button shutdown button ,hdd light, power light)my motherboard model number is intel d946gzis thanks and regards awais khan
  • 724 Answers
Related wiring to the front panel trace their origin and look for the pins related in the front of the motherboard. Match power button wires to the PSU or motherbord interface plugs.
Posted on Aug 24, 2010
PC turns on but shuts down after
shutdown may be caused due to following reason:
overheating
power supply issue
motherboard failure
remove anny external devices if connected to PC...lke graphic cards, wireless cards, external USB or HDD and try
Feb 11, 2012 | HP Computers & Internet
Gm5472 power button is broken need to replace or bypass
The Power On switch is located inside the plastic Power On button assembly.
It is an ATX power on switch.
This switch is a Momentary Contact Switch.
http://support.gateway.com/us/en/s/PC/R/1009566/1009566nv.shtml
Click on - Components - in the list.
Go down to the heading - Cases and Case Hardware
Click on - 8016038R - USB Ports/Power Switch Assembly for Gateway 5-Bay uATX Case
Click On Product Views, then Main View.
From a quick search on the internet,
1) http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=6400
2) http://www.bigestock.com/searchres.php?partno=8016038R
While you're waiting for the assembly to arrive, or if you want to just get the computer up, and running again, I suggest this;
http://www.directron.com/atxswitch.html
If you do not wish to wait, you may want to check local 'Mom and Pop' computer stores.
('Mom and Pop' computer store. The small shops run by those who enjoy computers, and are not looking to make a 'killing' in profits)
This is the motherboard in your Gateway GM5472 Desktop PC,
http://support.gateway.com/s/MOTHERBD/Shared/4006203R/4006203Rnv.shtml
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
The Front Panel header is right next to the four Orange SATA connectors on the motherboard.
This is the Front Panel header pinout,
http://support.gateway.com/s/MOTHERBD/Shared/4006203R/4006203Rmvr15.shtml
The pins are numbered. (Look close, and you will see a 2, under the left side of the black connector base)
Pin numbering starting from the Bottom, and going Up on the Right side,
Pins 1, 3, 5, 7, and 9.
Pin numbering starting from the Bottom, and going Up on the Left side,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. Not Connected to my knowledge.
D) Pins 2 and 4 are for the Power On LED light.
E) Pins 6 and 8 are for the Power On switch.
F) There is no Pin 10, therefore N/C. Not Connected.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2011 | Gateway GM5472 PC Desktop
Computer Worked Fine, Shutdown to move it, hooked back up and nothing. No Fans, No Light, No Nothing.
Open the side panel of your computer chassis and ensure that all power connections are making good contact with the mainboard. You will need to go through all internal connections and push them in.
Pay special attention to the 24Pin mainboard power connector and the 4Pin CPU power connector. Also check that the power switch is connected to the header on the mainboard. The header for power switch can be found near the power and HDD LED connections.
Take care!
damnor01
Jul 13, 2011 | Gateway GM5472 PC Desktop
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
Power supply green light flashes and computer won't turn on
hi
if your getting power ligh then chack disply setting from Bios still you have prob then just chack you HDD and Processor
May 30, 2010 | HP Pavilion a800n (PP163AA) PC Desktop
Guys ive only just got my ps3 and now it keeps comming up i need to restore my ps3 because its corrupt.... once i restore it, it comes up again with the restore screen? any help would be greatful as ive...
the corruption is from your HDD and yes, you might need to replace the HDD. But before you replace the HDD, you can try the steps below as it should help to solve your problem, but if it does not, you will have no choice than to replace the HDD. Follow the procedures below:
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good luck.
May 17, 2010 | Sony Playstation 3 (PS3) Console
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
Front panel wiring
Hi, Maybe we can wing it if you can send an image of the motherboard closeup on the F_PANEL connections and the wires from the front panel itself, or get the specific motherboard model during POST so we can try getting URL of manual. In some instances, the front panel wires are: Green wire, power on green light +, white wire is power on green light -; Red & Black, speaker; Red & white - HDD red activity light indicator where red is HDD + & white is HDD -; Orange & white - Reset Black & White - power on Post back so we can figure things out. Good luck and kind regards.
Aug 23, 2007 | Micro Electronics PowerSpec 8250 PC...
Intel D946GZIS Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
