Question about HP LaserJet 1022n Printer
What will be the price for Teflon sheet & Pressure roller for HP lj1022 printer
3 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: which part does teflon sheet sits in HP laserjet
If you are trying to print on 'teflon' sheets - then use tray 1. And make sure that you set the driver to TEFLON, the driver in the application, that is.
Posted on Apr 07, 2010
  • 1751 Answers
SOURCE: how to replace teflon sheet
he call it drum chack here how
utube.png You-Tube video "iMiTopIVMxM" placeholder (do not delete) utube.png
Posted on Oct 29, 2010
What's a fuser?
No fusing part in inkjet technology printers. Laser printers only having this part to bonds the image on paper. The fuser contains main parts of heater, teflon sleeve & pressure roller. Fuser produces the heat & fix the image on paper with the help of teflon sleeve and pressure roller.Ideal Image of fuser internal parts:
Dec 17, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Coming tuflon tape from back side of the printer 1018 hp laser
Teflon sheet got damaged replace it if you are service guy or else better to submit in service center..users are not advisable to do this activity..Tech guys: Remove left,right,back & top covers, take out fuser assm, open it, replace teflon sleeve..
Dec 16, 2011 | HP LaserJet 1018 Printer
The print smears on the page. I need to print several copies before the print will not smear.
Symptom that Teflon sleeve not rotating properly..If you are Tec guy replace Teflon sleeve & Pressure roller at a time to shoot out the issue..or else replace fuser assembly.. P/No:RM1-3740-000(120V),RM1-3741-000(220V)..if you are observed grinding sound, replace 20T gear P/No RU5-0378..Along with the fuser..See the snap shot..10_28_2011_5_41_54_pm.jpg
Oct 28, 2011 | HP LaserJet P3005n Printer
Paper crunches inside the printer
Check any paper particles jammed in side? open fuser assembly, check teflon sleeve,pressure roller & .. found any damage replace it if available or else replace the fuser assm. Note: Little bit technicality required to do the above said process..
Oct 01, 2011 | HP LaserJet 1100 Printer
Vertical grey line about 2 inches wide appearing to the right of the page. Print seems ok apart from this. Tried new cartridge but still happening.
Teflon sleeve might be damaged, My suggestion replace both Teflon sleeve & pressure roller if available or else replace fuser assm..
Sep 27, 2011 | HP LaserJet 6L Printer
2 pages are accrdianed in the very back of the printer. I cannot see a way to open to get them out. Is this a case where I have to just pick them out?
Paper might be roller on teflon sleeve, take out fuser from the printer, remove paper gently to avoid damage to teflon, after removing the paper observe that is there toner particles deposited on teflon sleeve, if observed replace the teflon sleeve,other wise this problem will repeats again & again.
Note: for this process technical skills required.
Sep 24, 2011 | HP LaserJet 1300 Printer
My Toshiba 1360 is jamming every other sheet at the exit from the heated roller. It seems that the paper is curving down slightly and catching on the ribs before the paper exit sensor switch. The switch...
At the exit of the printer, there is the fuser unit (heating roller, which heats the paper to fuse the toner on to the paper. The fuser (heater) is covered with the Teflon sheet Sleeve. So that the paper is never directly in contact with the heater and heat is transferred through Teflon sleeve.
I have noticed Paper Jam at the outer paper bin in case of damaged Teflon sleeve. A very clear indication of broken Teflon is that there is a loud cracking noise, when the printer initializes (printer power on) or while printing a page. Secondly, the toner fails to fuse properly to the paper and gets erased when rubbed. You may use a torch to inspect it as well. Secondly, inspect the paper path for any obstructions. There may be a torn piece of paper. Inspect the gears and roller from the input tray to the paper exit point and look for any stuck roller.
So, it is recommended that make sure that the Teflon Sleeve is OK and there is no obstruction in the paper exit path.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Toshiba 1360 Black and White Copier
When I print there are smudges on the sides and then begins mirroring words onto the paper
Ghosting and problems on the edges are often caused by a bad fuser. Remove the fuser from the printer and have a look at it. The upper roller in the fuser is the heat roller and it has a teflon cover on it. If that roller looks dirty or has toner accumulated on it or the teflon cover is shorter than the other roller or has visible damage then you will need to replace the fuser. The good news is that supplies for this printer are very reasonable in price.
May 23, 2011 | HP Color Laserjet 3550 Printer
Which part does teflon sheet sits in HP laserjet printers
Dec 07, 2009 | HP LaserJet 3015 All-In-One Printer
Uneven color in a document
check out ur drum or try out blowing the dust in between teflon n pressure roller
May 27, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1022n Printer Logo
224 people viewed this question
Seeker5211
Seeker5211
