I have a Fisher & Paykel Smart Drive 9 Excellence 7.5 GW709 washing machine and when turned on it tries to pump water into the machine a few times but then stops and i get an error code X000000XX (green, orange and red lights on)and it beeps at me in single continuous beeps...can you please help me with a link to the reference for the error codes and information on how to rectify this particular issue ... cheers
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.From the information in your posting the error on your machine is called, Repetitive Rotor Sensor Error.This means that the most likely cause of the fault is the Rotor Sensor.This component is located underneath your machine attached to the motor.The other 2 reasons that this fault is occurring is faulty wiring to the rotor sensor or a faulty control module.To test the rotor sensor unfortunately you need an RPS TESTER.But if you have an electrical test meter I can help you test the wiring to the rotor sensor.Please reply and let me know how you would like to proceed and I will help you as much as I can.
Posted on Aug 24, 2010
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
Fisher and paykel Smart Drive 9 excellence 7.5 washing machine wont fill at the start it just makes sounds like its trying then starts beeping?
the water soleniod has went bad pull out washer look to where water lines hook up to it turn of water to them then remove hoses unplug machine remove the soleniod valves make sure you write down the wiring order and hose placement on something get new valves replace rehook water line turn on water ect.
Aug 20, 2014 | Washing Machines
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
