Question about Cell Phones
In spite the SIM inserted properly, I still get the message "Insert SIM card"
mixmaster
  • 626 Answers
SOURCE: sim card rejected / insert sim card
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
Posted on Sep 12, 2007
mixmaster
  • 626 Answers
SIM card rejected means the SIM card has failed, it needs to be replaced.
Best of Luck.
Posted on Nov 22, 2007
SOURCE: Unlock MOBILE / SIM card LG KG220
i bought my phone throught e-bay too i got optus sim card ask me about secuirty code (sos) i just put 4 zero ( 0000) the phone accepted and un locked try that
Posted on Apr 24, 2008
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
  • 5 Answers
SOURCE: Insert Sim Card
WWATER GO INSIDE TE PHONE REMOVE BATTERY BLOW IT
Posted on Sep 16, 2008
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Nokia 3110 insert sim card problem
insert sim card message comes when there is no sim inserted or the inserted sim is not properly seated.pl chk
Mar 03, 2012 | Nokia 3110 Cellular Phone
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
When i insert my simcard to my phone always say insert sim what should i do with my problem in my sony ericcson k610i?
If that was the message that comes out on your phone after inserting the sim card,Its just means that it is not properly inserted.Try to make sure that it was not inserted in other way,upside down.Try to rechecked the With the metal contacts facedown, align the notch on the SIM card with the notch on the SIM slot and insert the SIM card.If also means that the SIM that yuo are trying to insert has been used and has password on it.Try to insert the SIM to its original phone and unlocked SIM codes.Previous codes has been entered on it.If that is a new SIM there might be problem with the SIM slot.try another SIM card to diagnosed the real problem..Hope this helps..
Jun 20, 2011 | Computers & Internet
My phone often pop mgs ''insert sim card''
you simcard maybe damage but try to clean it with an eraser.
Oct 13, 2010 | Nokia E71 Smartphone
My proble is i insert sim in mobile massage show please insert sim. my mobile model is m200 samsung
Hi, when a phone displays an insert sim message, it means that either the Sim card or the Sim tray where the sim card is inserted in the phone.
First, You can use the sim card on another phone to be sure that the sim card is still working properly. If the sim works with another phone, that means the sim tray where the sim card is being insert into the phone is bad and will need to be replaced.
You `can contact a skill personnel for help.
Have a nice day.
Sep 23, 2010 | Samsung M200 Black OEM GSM Unlocked Cell...
No network coverage
Phone is not receiving any radio signal / received signal is too weak:
Confirm that network coverage is available where you are by contacting your service provider.
SIM card is not working properly:
Insert your SIM card into another phone
Note: Contact your service provider if you get the same message again.
Phone is not working properly:
Insert your SIM card into another phone. If the second phone works with the inserted SIM card, then
the problem is probably with the first instrument.
Note: In this case, contact your nearest Sony Ericsson service center regarding your phone problem.
May 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
SIM card error
its probably not sitting proper;y and making full contact
Aug 26, 2009 | Apple iPhone Smartphone
Samsung D500
Make sure you have insert SIM card, and it is inserted properly in its place.
Jan 04, 2009 | Samsung SGH-D500 Cellular Phone
Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Nov 26, 2008 | Nokia 6080 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
