Question about Jura Capresso Impressa X7 Espresso Machine
Jura impressa X7. I have gone through the decalcifying process as per the instruction manual however "decalcifying necessary" is continually displayed on the screen and the machine is still going through the process after several hours. It seems like the machine keeps going through the decifying process without realising it has already finished. Any help woud be greatly appreciated.
SOURCE: Jura impressa x90 keeps beeping
may need descaling, if this is the case you always need to descale first
Posted on Jun 23, 2009
  • 13 Answers
SOURCE: Where can I find an Jura Capresso Impressa F9 replacement lid
The only sources I have been able to find are in Europe. They do not always wish to ship to the US however. In the US the dealers always want the repair, but seldome wish to sell parts outright. Try this website for parts.
Mike
www.juraprofi.de
Posted on Jul 05, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Jura Capresso Impressa S9- no steam
Great solution - solved 80% of the problem I had - would also add to check the pressure relief valve (back of pump where water lines to thermo blocks attach). Noticed presure was still low after cleaning solenoid. Ran steam with cover off top (cup warmer plate) and notice water flow in clear line at top (you will see the line). Went to pump, pulled off hose block at back of pump, and popped (carefully) off the black cap which separates the water to the brewer from the steamer. Cleaned this needle and seat, and the spring too, and the pressure now is extremely high at at the steamer wand. 100% fix now.
Posted on May 12, 2010
espressonist
  • 1711 Answers
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
Jura Impressa x7. What is cause of malfunction 8 error?
Pretty unit...
I do love my coffee...!
Judging by the number of positive hits, diagrams... & retail parts houses... you may not have done too badly.
Check out the search page posted at the bottom
http://www.bing.com/search?q=jura+impressa+x7+parts&form=PRDLC1&src=IE11TR&pc=EUPP_DCTE
Capresso Impressa Replacement Parts
Jura Capresso Parts Capresso Parts
Mar 24, 2016 | Coffee Makers & Espresso Machines
While decalcifying the water comes out of the frother in intervals as it should but it does not come out of the spouts.
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
Sep 30, 2015 | Jura Capresso Impressa F7 Espresso Machine
Jura impressa x7 keep getting report fill water tank
make sure the water tank is full! there is a small float in the tank that moves up and down near the bottom, make sure this is up and not stuck down.
Feb 05, 2014 | Capresso Jura Impressa X7 220v
My jura X7 system is rinsing with milk. When pressing the rinse button, the machine is drawing milk to rinse instead of water??
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
Aug 15, 2013 | Jura Capresso Impressa X7 Espresso Machine
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
Jura Impressa J, where do you insert cleaning tablets. Round tab to the left of bean hopper is too small for tablet
There is a little shoot that you pull up between the grinders, the pills fit there, if they do not they are the wrong pills. they should be semi circle pills
Jan 12, 2010 | Jura Capresso Impressa X7 Espresso Machine
I am having trouble starting the decalcify program, even though the light blinks "ready/decalcify"
Had the same problem, i noticedt that there is a procedure to run decalcify anytime in the instructions book.
Turn off the machine, press Rinse button until it says Empty Tray then go go Step 2 in the instructions.
Nov 27, 2009 | Jura Capresso Impressa F7 Espresso Machine
Where do you put the cleaning tablets in a jura impressa x7-s?
add a capfull of the cleaning fluid to a litre of water, insert milk tube and request cappuccino clean from the cleaning button...icon of cleaning tablet surrounded by water droplets, second row second button from lefthand side...then follow screen instructions to step your way through the cleaning selections with +and - buttons.
I keep the cleaning fluid held high to allow it to continue running after the cleaning action.
Remember to run clean water through the pipes using the same method above.
Google x7 manual and you can download one of many copies online.
May 05, 2009 | Jura Capresso Impressa X7 Espresso Machine
Jura Capresso Impressa X7 Espresso Machine Logo
226 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
