posted by kelyco on May 05, 2008
I would like to program the URC-R6 to operate the dvr on my Scientific Atlantic receiver. While it has dvd/dvr/vcr buttons, there isn't a LIST button (or anything else) to access the recordings. Is it possible to program the URC-R6 for use with the dvr?
Thanks
1 Other User Has The Same Problem
Comment by sweetnnotng, posted on Jun 21, 2008
I have a universal remote that I just got and just found out when I called the tech support # on the back of the box, it's missing the book. SO I need a code for a yamaha DVD. And the instructions on how to work it. And it will save me the time not to go back to Best Buy. So please can anybody help me?
Provided by LOGITECH STAFF
Solution #1
posted on May 05, 2008
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
IrishDruid
- PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
- PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE
slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.)
button until your device turns off. (On VCR, LD, and CD players use PLAY
instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes. - When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
- PRESS and HOLD the SETUP button until the red LED flashes twice.
- PRESS 9 - 7 - 5, the red LED will flash twice.
- PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
- PRESS the button that will receive the learned function, the LED will flash rapidly.
- PRESS the button on the original remote to be learned.
Hope that helps!
- "FixYa!" - The solution provides great advice on how to solve the problem.
- "Helpful" - The solution provides useful leads that helps solve the problem.
- "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
- "Inappropriate" - The solution has absolutely nothing to do with the problem.
IrishDruid
Comment by IrishDruid, posted on May 31, 2008
This thread has gone 14 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
Or post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
Thank you.
IrishDruid
Thank you.
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE 84918 Remote Control
GE JASRM84964 Remote Control
GE RM24906 Remote Control
GE RM24925 Remote Control
Jensen SC-340A Remote Control
Jensen SC-570 Remote Control
GE RM24948 Remote Control
Can you Help with these Remote Controls problems?
Directed 3 BUTTN 434MHZ 2/66 CODES REMOTE...
codes remote control RCA for
codes remote control RCA for my... Answer This...
Philips Universal Remote (PH301S) Remote...
programming my universal remote
Lost the manual. Not sure of... Answer This...
Philips Magnavox Learning Universal Remote...
the converter box turns on
the converter box turns on and... Answer This...
Repair Service
Find Remote Control Repairman Near You:
