The expansion tank that holds the coolant keeps evaporating although the radiator cap is new, I think the psi is not the correct pressure for this particular model, the cap I have on now is 1.1 psi. Is this correct?
    Problem Solver:
  • 18 Answers
Most older radiators use a 8 or 10 psi cap newer radiators use a high presure cap 15 or 16 psi cap check your manufacture for the proper cap rating.
Posted on Aug 24, 2010
Why coolant level in refill tank drops with no apparent leak?
Hi Ayaz
if there no leak detected that means the radiator cap is not holding the pressure, that cause the coolant to travel to the expansion tank and flood out, then when engine cool down, it will suck the coolant back to the radiator and leave the refill tank empty.
Replace the Radiator Cap
Good luck
Nov 22, 2015 | 2006 Toyota Previa 2.4
I changed lower hose from expansion tank - still have tiny leak from top of the hose - tried 2 different clamps - same result - during winter heater seems to have hard time to warm up ( berley warm air...
the temp gauge should be reading around the 1/2 way mark and the pressure is controlled by the radiator cap. Check the catalogue at you local spares shop and the cap recommended will hold the correct pressure for your car.
Oct 08, 2013 | 1998 Volvo S70
Water flowing out of radiator when idling 93 nissan terrano v6 petrol auto trans
If the coolant was hot when you noticed water coming out the radiator, that is normal from the heat expansion of the coolant. That is why there are coolant overflow tanks-also called coolant expansion tanks.
When refilling coolant, always top up the radiator, and fill the overflow tank to at least the cold mark level (about half-way up on the tank). With cap off, run engine till the thermostat opens- upper radiator hose will become hot-then shut off engine, add coolant to radiator as needed, replace cap. This method of filling will help to expel any trapped air in the system. Oh, and remember to set your heater controls on high when filling coolant, so the heater core and lines also circulate and expel air.
Check the seal on the radiator cap that it is still good. The cap seal is important to seal the coolant system, as it is a closed system under about 15 psi of pressure. The reason to pressurize the system is that the pressure will raise the boiling point of the coolant by about 10 degrees- important when you consider how hot the coolant has to be when running. OK, enough tutorial-I don't think you have a problem with the water pump! G'd luck, reeve.
Nov 22, 2012 | 1993 Nissan Pathfinder
Cant find the valve to let air pressure from my radiator for my water to flow right
FILL COOLANT SYSTEM UP BY POURING COOLANT IN THE EXPANSION TANK UNTIL COOLANT LEVEL STOP DROPPING IN THE EXPANSION.WHEN YOU POUR COOLANT IN EXPANSION TANK AIR BLEED OFF THROUGH THE SMALL COOLANT LINES GOING TO EXPANSION TANK.WITH PRESSURE CAP OFF RADIATOR COOLANT LEVEL IN EXPANSION IS AT FULL COLD MARK.WHAT YOU TO DO CRANK ENGINE UP LET IDLE WARM UP UNTIL COOLANT DROPS IN EXPANSION TANK KEEP ADDING COOLANT UNTIL STOP DROPPING STAY AT FULL COLD MARK.WHEN COOLANT LEVEL START RISING IN EXPANSION TANK.PUT PRESSURE CAP BACK ON RADIATOR.WHILE ENGINE IDLING WATCH TEMPERATURE GAUGE.IF START CLIMBING TURN OFF ENGINE LET IT SIT FOR LITTLE WHILE TAKE A LARGE RAG OPEN RADIATOR PRESSURE CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDING TO RELEASE AIR IN COOLANT SYSTEM.WHEN PRESSURE IS RELEASED OPEN PRESSURE CAP ADD MORE COOLANT IN THE EXPANSION TANK.CRANK ENGINE AGAIN LET IDLE WHEN TEMPERATURE GAUGE START CLIMBING. TURN OFF ENGINE WAIT FOR WHILE BEFORE OPEN RADIATOR PRESSURE CAP.WHEN YOUR THERMOSTAT OPENS WHEN TOP RADIATOR HOSE IS HOT AND ENGINE COOLANT TEMPERATURE GAUGE STOP CLIMBING AND COOLANT LEVEL STOP DROPPING IN THE EXPANSION TANK.ALL AIR IS EXPELLED FROM COOLANT SYSTEM TO KEEP ENGINE FROM OVERHEATING.
Jun 10, 2011 | 2001 Cadillac DeVille
Just need to know where to put the coolant
If you don't have a radiator cap or a cap in the upper radiator hose, you have to add through the Overflow. Cavaliers are this way. It takes forever to burp the air out of them. Be careful that you don't stop before all of the air is out. An aid pocket in the cyl head will damage your engine.
May 09, 2011 | Oldsmobile Alero Cars & Trucks
I changed our my rediator and now the sensor light saying radiator coolant is low and the buzzer won't stop going off. The radiator coolant level is fine and my temp gauge is fine. Any help would be...
Do you have an overflow tank that has low level in it?
LEVEL CHECK The coolant level should be checked regularly. Serious engine damage can occur if the engine overheats. CAUTION
Check the coolant level when the engine is cold; serious injury could result from escaping steam or hot fluid if checked when hot. If your car is equipped with an electric cooling fan, make sure that the ignition switch is OFF. The cooling fan will automatically operate if the ignition switch is on and the engine coolant temperature is high, or if the wiring connector on the thermostat housing is disconnected.
  1. Depress the button on the thermal expansion tank (coolant recovery reservoir) safety cap, if there is one. Allow all of the pressure trapped in the system to escape. CAUTION
    The radiator is not factory-equipped with a safety cap. Do not remove the radiator cap before removing the expansion tank cap, or when the engine is hot. Fig. 1: Remove insects and debris from the radiator fins 85811096.gif
  2. Remove the expansion tank cap. The expansion tank should be 1⁄3 full, unless Full and Low marks are provided. The level should be well above the bottom of the tank when the engine is cold.
  3. If it is not, carefully remove the cap from the radiator. The radiator should be full.
  4. Add a 50/50 solution of ethylene glycol (or other suitable coolant) and clean water. If there was no coolant in the expansion tank, fill the radiator until the level is near the inlet port and install the radiator cap. Then, fill the expansion tank to the specified level, and secure the expansion tank cap. When checking the coolant level, the pressure cap should be examined for signs of age or deterioration. Check it for a worn or cracked gasket. If the cap doesn't seal properly, fluid will be lost and the engine will overheat. A worn cap should be replaced with a new one. The fan belt and other drive belts should be inspected and adjusted to the proper tension. (Please refer to the belt inspection and adjusting procedures, earlier in this section.) Remove the radiator cap and run the tip of your finger around the inside of the filler neck. Check for excessive deposits of rust or scale around the filler neck lip and the filler port. Make sure the coolant is free of oil. Replace the coolant as necessary. Hose clamps should be tightened, and soft or cracked hoses replaced. Damp spots, or accumulations of rust or dye near hoses, the water pump or other areas indicate possible leakage, which must be corrected before filling the system with fresh coolant. Periodically clean any debris, leaves, paper, insects, etc. from the radiator fins. Pick the large pieces off by hand. The smaller pieces can be washed away with water pressure from a hose. Carefully straighten any bent radiator fins with a pair of needle nose pliers. Be careful as the fins are very soft. Don't wiggle the fins back and forth too much. Straighten them once and try not to move them again.
Jul 05, 2010 | 1985 Mazda RX-7
What is the coolent reserve tank for???? IF broke does it need to be fixed immedatley? Mine is busted and I was wondering if my car is going to overheat now. THANKS
The coolant reserve tank is a medium for the radiator to breathe. Water passes from the radiator to the coolant reserve tank and fort.
The car might not necessarily over-heat if the coolant reserve tank is broken, but it is advisable that you replace it to enable it serve its purpose within the operations of the car engine.
Good luck.
May 27, 2010 | 2004 Toyota Avalon
2003 kx250 coolant flush
Look for where the tube from the radiator goes to the pump on side of the engine there should be 1 screw which has a fibre or copper washer,undo this.
Hold a suitable container covering the hole then take off the radiator pressure cap & watch it gush out!!
Flush with water ( put a hose to the pressure cap & rinse)
Replace bolt & fill rad & expansion tank with fresh coolant, run for 5 - 10 minutes then top up the expansion tank to max
expansion tank
Hope this helps (if so please mark as helpful !!)
Ride safe
Bike-Doc
Apr 21, 2010 | 2003 kawasaki KX 250
1991 overheating Towncar
If car heats up quickly and overheats , the problem is the thermostat. The thermostat stays closed and traps coolant in the engine untill it reaches about 185 degrees , than the thermostat opens and allows coolant to flow to the radiator where it is cooled by airflow. ( airflow while driving is usually sufficient ) while idling , or in slow trafic , the fan keeps air moving through the rad. The heater core is strictly for heat in the winter inside the car. The thermostat is the most likely cause of the problem , and even if it was good before , the overheat / boil situation likely cooked it anyways. I am assuming the water pump is still getting turned by a belt. No water circulation by pump would cause same symptom as bad thermostat. Overflow and expansion bottles are designed several different ways on different cars , but the theory is that as the engine heats up and the coolant expands , it goes to the tank. Later , as engine cools down after being shut off , coolant contracts. Radiator is replenished by coolant returning from expansion bottle.
Jun 04, 2009 | 1991 Lincoln Town Car
Water leak from top of expansion tank.2000 BMW 316i se
The water (coolant) in the expansion tank will rise and fall with the engine temperature. What the expansion tank does is collect and return coolant to and from the engine. When the engine warms up the coolant gets hot, builds up pressure and opens up the radiator cap. The coolant then goes into the expansion tank. Now when the engine cools down the pressure drops in the cooling system and the pressure drop (vacuum) pulls the coolant back into the engine via the radiator cap. The radiator cap allows the cooling system to build up pressure and by doing so increases the boiling point of the coolant, but when that pressure exceeds the caps rating the cap opens and the coolant goes to the expansion valve. The cap has another part to it that when the engine cools down and a partial vacuum is created in the cooling system a "valve" in the radiator cap opens and allows the coolant to be drawn back into the engine. I would look at your radiator cap to see if any gunk or build up is on it, and check the rubber gaskets for cracks. It's easiest just to replace the cap because they are inexpensive and easy to replace (2-10 dollars). The expansion tank should have two hoses on it. The one on the bottom comes from the radiator and the one on the top (possibly part of filler cap) runs down and is open to the ground. That way if it is overfilled or becomes overfilled it will slowly leak onto the ground. When and if you change your radiator cap, make sure the engine is cooled down, remove cap and start engine and turn heater to full blast, full heat. Leave the cap off and let it run until engine warmed up. This should burp out any air pockets that may have happened when coolant was changed. Also top off the coolant in the radiator while it is running. Hope this helps and good luck
Apr 03, 2009 | 1992 BMW 3 Series
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
