We have the above set top box and was working fine but my daughter played with remote and now none of the display for channels are working, the sounds still comes through. We are wondering if there is a key lock that she might have done but have pressed all buttons on remote and none have changed the outcome. We have turned off at powerpoint and problem still remains. We have no manual.
  • tanyaorgill Aug 24, 2010
    Our set top box brand is DGTEC. There is nothing wrong with TV as our video and DVD run through TV and they are still working as is the TV, it is just when we try to use the set top box for the digital channels as our TV is still analogue. The screen is dark grey not snow.
  • 11,800 Answers
It would help if we would know the exact brand and model of your tv and set top box and with what cables they are connected.
In the mean time you can do some testing on the tv to make sure it's a setting problem , not an actual fault: take out all the cables from the tv, plug an aerial antenna in it, select the antenna as a source and try to see something - even if you see just snow it means that the tv as a whole is operational
To see if the box is ok all you have to do is to plug it in another tv and try to see something with it. If you can't then it's time to call the cable guys, the box is done for.
Posted on Aug 24, 2010
  • Azrael SRL Aug 24, 2010
    In that case the problem is definitely in the box. When you press the Menu button for the box it appears on the screen or not? If not then the video settings might have been changed and to fix that i need the exact model number of your box. Or you could call the cable guys who installed it in the first place, it's their job to fix it for you for free if it's defective.
Not all buttons on All for one URC-2981 remote control working for Sinotec TV
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 30, 2013 | Televison & Video
My converter box, which was working fine until about two months ago, will not change channels, although the remote will turn the converter box on and off.
Is the converter on any particular channel?
Are there set top controls? Do they work?
Do you have a picture?
Has any thing been changed recently, like wiring?
Have any children been playing with the remote?
Mar 31, 2010 | Insignia Digital-to-Analog Converter for...
DVB8800HDhas stopped working
Our Celestial set top box has been fine for a year or so but jjust stopped last night. I can turn it on or off but it no longer displays a channel number or menu details. Any ideas, or is it dead?
Feb 13, 2010 | Televison & Video
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Sound problem on Technika LCD19-907
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jun 19, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
"Not supported Mode" message
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Nov 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Bush 2878N TXSIL : Instruction Manual and Remote ?
Nov 02, 2007 | Bush 2871NTX 28" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
