Question about KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
I emptied the ice container two days ago and the ice maker has not made any ice since. There is nothing blocking the senser and the switch is in the on position.
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
I have a problem with the ice maker on my fridge and I'm pulling my hair out trying to figure out why it wont continue to produce ice.
If the ice maker continues to have ice in the slots and will not empty into the ice container it's more likely a problem with the ice maker and it needs replaced now I see you did not post your model number so I am assuming that you do not have infrared light showing that the ice maker has the container full. If your refrigerator has an infrared light beam then that could be a problem what is the model number of your refrigerator? Appliance 911 Sea Breeze
Dec 16, 2015 | Refrigerators
The ice door will not open like it used to. Now I have to reach in with my fingers to open it to get ice through the door.
Good Morning Misty, thank you for your post!
It is a good idea to clean the ice dispenser and ice container if the ice dispenser sticks or before contacting an experiencing technician to assist further.
1. First, stop ice production by lifting the wire signal arm to the "up" or OFF position (side-mounted) or the ice maker's On/Off power switch turned Off-set to the "O" position (rear-mounted).
2. Remove ice container by lifting up and out. Empty and carefully clean the container with mild detergent. Rinse with clear water. Do not use harsh or abrasive cleaners. Allow ice container to dry completely before replacing in the freezer.
3. Remove ice chips and clean the shelf and chute that supports the ice container.
4. Replace the ice container. Lower the wire signal arm on the ice maker to the "down" or ON position (side-mounted) or the ice maker's On/Off power switch is turned On-set to the "I" position. (rear-mounted) and the ice maker will resume production.
I hope these troubleshooting tips help you in some small way.
Sep 24, 2013 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Model 106.57036601 Ice maker quit working couple days ago had water off in whole house, had to repair a water pipe in the restroom.
There are a couple or three ways to test your ice maker and dual water control valve to identify the location of the problem. By looking at what the ice maker did on its last cycle or the lack of a cycle will help a lot. If ice maker has old cubes then the ice maker has not cycled and that tells me that the ice maker has been turned off or it has become defective. Another test is to pour tap water into the empty slots if there was not old cubes there. Allow the water to freeze and if the ice maker cycles and dumps the cubes into the ice container that would indicate a defective dual water valve=> 4389177 Water Valve Kit- Double Outlet The first three numbers of your model tells me it was made by Whirlpool and that tells me that removal of the front cover of ice maker you have test points. If me knowing what I know of ice makers I would be prepared to change both ice maker core=> 2198597 Ice maker - Replacement
Below is a short You-Tube ice maker help tutorial by the Appliance Assistant that can be very helpful. Should you have questions please ask, Thanks, Sea Breeze
Jun 10, 2011 | Kenmore 56733 Side by Side Refrigerator
Ice maker does not work.
Make sure the wire lever is pushed down calling for ice.Otherwise the unit thinks its full.
Jan 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
74 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
