Haier air conditioner model esa408j-l it leaks water wat can i do
    President:
  • 3,773 Answers
Clean floor under both coils inside so water can flow to the back drain or pan.
Be sure the unit tilts a bit to the rear.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
  • jcmicah68 Jul 11, 2011
    There is no drain or pan. What now?
  • Leo Ponder
    Leo Ponder Jul 22, 2011
    Clean under the coils anyhow. The cond Fan will take care of water in the back in the pan
    Like in my solution the Pan is under the cond coils.
    Thank you for using fixya
    Leo Ponder
    Please rate me if this helped.
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
Why doeshaier air conditioner model esa408j-l it trips
1) There are varios reason a) the capacitor you must test for shor b) the motor can be short c(switch can be short. d) test the power cord for loose wires or touching ground.e) compressor faulty.see the diagram attachedand proceed according with common sense, God bless you
May 14, 2012 | Haier Heating & Cooling
Hello, I noticed yesterday that my air Haier ESA408j-l window air conditioner was dripping an excessive amount of water into the window. Most likely due to the high heat and humidity in the area, the air...
Dry it all out and try again . but be very carful and be certain you are not coming in contact with any water when you plug it back in and yes it will take more thatn atowel to keep things dry move it to the window and be certain it is tilted to theout side a little
Jul 19, 2011 | Heating & Cooling
Haier CPN10XC9 leaking water. Have drained the
I had the same problem, removed rear cover (15 screws) and found a drain slot under the conderser plugged with dust and grime. gently cleaned the slotted area out with a Q-tip, and the condensate is now following the proper flow into the tan and evaporator. It has been running for 2 hours with no drips!!
Jul 17, 2010 | Haier CPN10XC9 Air Conditioner
HAIER Model # HWR06XC3 not working :(
If this does not work, call an air-conditioning technician--the refrigerant ... 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. ... may be blocking the water's flow, or leaking, or the pump may not be working. ...
Jul 09, 2010 | Haier Heating & Cooling
AIR CONDITIONER IS MAKING A NOISE LIKE ICE IS IN IT BUT IT IS WAT
All A/C units will produce condensation from time to time, depending on relative humidity. Your problem seems to be an accumulation of this condensation which has no way to escape the unit. Most likely the drain port is clogged with debris. Clean the debris and the unit should drain normally.
Jun 27, 2010 | Haier ESA306 Air Conditioner
Leaking water
Very common problem with these systems. This depends on humidity in the air. Some systems have a setting that you can turn off the dehumidifier. The downside to this is it doesn't cool quite as well as humididty absords heat. The drain pan in your system is probably overflowing. You have a couple options, you could "hard drain" it to outdoors, empty the drainpan regulary, or change the air settings (this may not solve completely if you live in a humid area).
Aug 30, 2009 | Haier HPM09XC5 Portable Air Conditioner
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
