I have a receiver and accidentally locked one channel. Problem is i do not know how to unlock the parental lock. what is the usual default lock code for parental lock?
    Scholar:
  • 122 Answers
If you have not set a code for it, most parental lock default codes are simply 0000. If more than a 4 digit code, just put all zeros.
Posted on Aug 24, 2010
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tip
Mitsubishi lock code
Mitsubishi Television asking for an unlock code.
Well you locked the set and forgot the code, or someone has locked the code before you got the set. One other scenario is that the code was entered by someone accidentally. Please note: If your parents have locked the television you should not be unlocking something that your parents have blocked. So don’t use these instructions to unlock a television that your parents have locked.
You must have the original Mitsubishi remote control to perform this operation on the set. Look on the remote for a button that is labeled QV (Quick View), if you have this button on the remote then we can press on. Go to the selected channel or input that is asking for the unlock code. When it asks for the code, press the QV button: Holding it down press the number 9 and release. This will unlock the set for this instance. To remove the code I suggest that you go through the setup menu and find the code lock and when it asks for the code use the QV+9 trick again to turn it off from the main menu.
If you do not have the original Mitsubishi remote you will not be able to try this trick. You will have to order a replacement remote from 1-800-REMOTES or www.remotes.com.
Once you have the replacement remote you can unlock the television and be back on your way.
I hope that this helps you with your television lock issues and as always, Thank you for using FixYa.
asnowman
on Mar 22, 2010 | Televison & Video
Hard reset
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Jun 08, 2013 | Akai CTD-1390 TV
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
My akai tv is locked,don't know the code
Instructions
Sep 13, 2012 | Jensen Q2749J 27" TV
Cant unlock pin number jvc LT-32DR1BJ
Instructions
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | JVC Televison & Video
How do i set parental guide code
Using your remote control....
Select Menu
Select User Settings
Select Locking
You now have a choice;
If you want to completely lock your receiver...
Select Receiver Lock (note; default code is 0000)
If you want to lock certain channels...
Select Channel Locking
Select Yes
Select channels you want to lock on 'Channels to lock' screen
There are different levels you can use.
If you want to change your lock code...
Select User Setting
Select Change receiver Code.
Regards
Zahc
If I've helped, please rate me.
Jan 26, 2011 | Sagem DTR67320Q
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Electro Med Services...
