Question about Epson Stylus NX400 InkJet Printer
My new Epson Stylus NX400 was plugged in 220V by mistake and does not turn on any more. Is it possible to fix.
  • 724 Answers
Fried the power supply
Can it be replaced at a cost that may be more then a new one.
It might be like making white bread out of toast.
Posted on Aug 24, 2010
  • tommya300
    tommya300 Aug 24, 2010
    How did u do that
I see ink inside my epson stylus nx400
Leaking cartridges or Bad printer heads. New printer is cheaper than fixing.
Feb 06, 2014 | Epson Stylus NX400 InkJet Printer
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Epson nx400 says its "Idle" and wont print.. can i
You may download software from here
Also check this link if you still have problems.
pls. vote for better service... thank you
Nov 17, 2010 | Epson Stylus NX400 InkJet Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
Epson R280 was plugged to 220V by mistake
you can not fix it by your self you need the power input place and if it had effect the buffer device than might it would take alot mony to get fixed...
Jun 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
