Question about Motorola Mobility L7I Cellular Phone
My l71 is 5 yrs old.Itz battery iz giving prblms.after talking 5- 10 mnts charges are going off, & then mble iz going off. What to do?
Battery problem
Posted on Sep 03, 2010
My dyson dc 59 has stopped charging only 5 mnts old
This could be due to premature battery failure or charger failure.
Jul 08, 2014 | Dyson Vacuums
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Lenovo battery 0% available( plugged in, not charging)
Your battery is probably dead, the only way to fix it is by taking it to a battery repacker (it will cost you more)
or you can simply buy a new one
Feb 15, 2013 | Computers & Internet
My phone is 3 yrs old. Lately the battery will not keep a charge. I charge it until it is fully charged, however if I talk for more than 5 minutes the phone logs off and dies. I turn it back on and the...
It sounds like your battery is faulty. 3 years of use is enough to wear a battery out. Try replacing the battery and see if the problem clears up. If it doesn't your phone may have an internal faulty, but I am going with the battery.
Apr 15, 2011 | LG enV VX9900 Cellular Phone
In My Mobile. camera is not working when i press camera button it close the application & come out .what should i do to solve this?
YOUR EXPERIENCING A BATTERY ISSUE
short battery life is contributed to these, 1. Old battery 2. Lots of apps running in the background 3. Taking lots of photos 4. Charging the phone when it does not need a full charge 5. Leaving your phone in direct heat or cold 6. Dropping the phone 7. Leaking battery 8. 1 year or more old battery 9. Continuously talking and charging at the same time 10. Ensure to contact your insurance to see if the battery is protected under your plan.
Jan 21, 2011 | Sony Ericsson W550i Cellular Phone
EVEN WITH A NEW BATTERY, THE CAR WILL NOT START. IT GIVES A WHIRRING SOUND BUT THE ENGINE WILL NOT ENGAGE. BEFORE PUTTING IN A NEW BATTERY IT WOULD START WITH A JUMP BUT NOW EVEN THAT DOES NOT WORK.
WELL SOUND LIKE STARTER IF YOU CAN TAP STARTER WITH HAMER IT MAY MAKE IT WORK BUT YOU WILL NEED SOME ONE TO TRUNE KEY FOR YOU IF IT DOSE MAKE IT WORK REPLACE STARTER BUT MY MONEY ON STARTER
Aug 19, 2009 | 1996 Volvo 850
Can I leave my 2004 ezgo golf cart charger plugged into the golf cart and wall all the time when golf cart not in use?
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Jul 21, 2009 | Electronics - Others
The AMP light came on my 1990 Olds Cutlass. The
It means that your charging system is in trouble. Possiblity is alternator...or the battery. Go to Schuck's/Kragen/Chief's/NAPA....they will test BOTH for free.
Jul 12, 2009 | 1990 Oldsmobile Cutlass Calais
Goes from fully charged to almost zero charge in seconds
HI,
Please make sure the charger is working.I suggest you try replacing it with a new charge and then give it a try.The problem can also be with the battery if it is more than 2-3 yrs old.In this case the problem is with the battery.
So i suggest if the battery is more than 3 yrs old buy a new one and then test it with the old charger and if the battery is not old then replace it with a new charger and try charging the battery.
Let me know the result
Jul 02, 2009 | Samsung BlackJack II Smartphone
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Motorola Mobility L7I Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
