Question about Whirlpool Calypso GVW9959K Top Load Washer
Hello. I have a two years old Whirlpool washing
Hello. I have a two years old Whirlpool washing machine model AWE 6516. Yesterday, during squeezing, the machine made a noise that I never heard from her and, most important, some oil leaked beneath. Please, could you tell me what part of the machine do you think is broken and what should I do next. Thank you.
  • Whirlpool Master
  • 17,129 Answers
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Posted on Aug 24, 2010
  • mdragos_1 Aug 28, 2010
    I have checked underneath the washing machine and everything seems to be fine, there is no hose or belt loose. Could you please let me know where is the oil comming from ? What part of the machine is useing it ?
    I'm trying to figer out if there is some expensive part broken or not.
  • Donald DCruz
    Donald DCruz Aug 28, 2010
    if there is a gear box assembly near the spindle, the oil would have oozed out through the oil seal ring.
    You can replace this if the model contains the assembly.and the noise must be coming out of low oil in the gear box. open and check
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Whirlpool Washer WTW4850Q1 makes loud noise during agitation cycle?
http://www.repairclinic.com/Shop-For-Parts/a11b5-x777477343835307131/Wtw4850q1-Whirlpool-Washing-Machine-Parts >Click on repair help written in blue. Its free. Hope this helped.
Jan 05, 2015 | Whirlpool Washing Machines
Hello, I have WHIRLPOOL washing mashine model AWE 2214. Yesterday during squeezing, the masine stoped without noise, no indication buttons.I cheked everything, but the mashine no start. Please, help me!...
Go to www.washingmachine-manual.com/whirlpool-awe-2214.html for the handbook. Make a cup of coffee and have a read up. If that fails to help then its an engineer I'm afraid.
If you have a good diy friend have them check the belt drive if it has one? Be careful of electricity and water, they don't mix.
Jul 21, 2014 | Whirlpool Washing Machines
Awe 2117 whirlpool over flow of soap
Remove the top and and check the hose from the dispenser to the tub for clogs and see if the actuator motor is working is what I would do using this handy dandy SERVICE MANUAL( For American models)
Sorry that is all I have. If you are across the pond you may be able to a manual from Espares.
Jun 17, 2012 | Whirlpool Washing Machines
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
Is AWE 6515 is a cold water fill only?
your model # is incomplete. look behind washer and if you see two valves, then one is normally for hot water hookup.
Jan 18, 2010 | Whirlpool Washing Machines
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Our whirlpool is leaking from the bottom during
our door gasket was leaking and running out the bottom... not sure how the gasket got holes in it but it had five or six holes and it is not that old. the gasked was over a hundred dollars and the water bill ran over a hundred dollars before I found the leak
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
