MANUAL for wfs1273BD - Washing Machines
  • 3,740 Answers
Thre are no merchants selling this washer today that I am aware of but you can contact Whirlpool here and ask for a manual:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvcnthome001
On an informational note the common last 2 digits of the Model number / Commercial code seem to be BW vs BD
Thanks for choosing FixYa.
Kelly
Posted on Aug 24, 2010
My whirpool washing machine ghw9250 has no power
Need a bit more info.
Have you checked the power at the power point?
plug a lamp or similar into the power point to check.
Are there any indicator lights showing on the front of the machine?
could be a main board, have come across a whirlpool wfs1273bd with a similar problem yeasterday with a similar issue, pwer to the main board but nothing out.
Jan 02, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool wfs1273bd leaks water from under the detergent draw when the hot water goes into the machine what should I do?
This product has to be my most hated product in the entire house. We have had nothing but issues with this piece of junk. 2 days ago water and foam started pouring out the soap dispenser and across the laundry floor. Not to anyones surprise as this machine has been a dud for 2 years.
So i finally got to looking at this tonight, and was blown away by a) what tiny little thing caused it, and b) the simplicity of it (did it in 1/2 hour) when I thought this was going to be a all night job with 1000 parts across the floor.
How its done:
  1. Remove the power and water pressure from the washer
  2. Remove the 3 screws at the rear of the machine on the top plastic trim (that hold the top of the machine on.
  3. Slide top panel of the machine towards the back, it will become dislodged from the front control panel.
  4. Remove the soap dispenser tray
  5. Undo the 3 screws in the soap dispenser frame, that join the front panel to the water mixing chamber
  6. Undo the two screw on top of the front control panel that are exposed from removing the top panel of the machine
  7. There are two clips, either side of the control panel inside the machine that hold the front panel on. I could undo the one opposite to the soap drawer, but I couldn't get the other, so jiggle the control sideways (left and right) and applied a pulling pressure and it came free. Rest the control panel on top of the drum, I didn't undo any cables, they seem to stretch over the front on top of the machine.
  8. Remove the bottom sump panel - apply a inward pressure on the top of the sides of the panel, and pull outwards. It will hinge away with the hinge on the bottom of the machine.
  9. Undo the screws that attach the entire front panel including door (two on top far sides, and 3 across the bottom.
  10. Pull the entire front panel forwards gently, and the lining between the front panel and drum will stretch out about 2 inches.
  11. Reach in around the front panel and you can see the black tube run down from the soap mixing box, into the main drum.
  12. Gently yank/pull the black tube away from the main drum, it has a rubber flange on the other side that stops it coming out, but it will come through.
  13. See if you can clear the blockage in the tube (if there is), you may need a pair of pliers to remove the black tube from the bottom of the soap box.
  14. Assembly is the reverse, ensure that you get a good seal on the tube back into the drum. I did this by forcing the flange back into the drum, further than it was originally, and slowly and gently pull it back out, until the drum lip pops into the ring on the rubber tube.
Notes: Dont lose the screws in the soap box down the tube, its a absolutely huge job to open the drum. Put a towel ontop of the floor drain in your laundry, its a icky job to retrieve that!
Good luck, and never buy a Whirlpool machine again!8_27_2012_9_31_19_am.jpg8_27_2012_9_32_25_am.jpg8_27_2012_9_33_06_am.jpg8_27_2012_9_33_59_am.jpg8_27_2012_9_34_42_am.jpg8_27_2012_9_36_14_am.jpg8_27_2012_9_36_34_am.jpg
Apr 22, 2012 | Whirlpool Washing Machines
Can we operate our WFS1273BD washing machine on cold water only? We are on instant gas hot water and have gone through a 45kg bottle in 3 weeks. We have lived in this house before and the washer is the...
ABSOLUTELY! Purchase a 'Y' adapter from your local hardware store and attach the hot and cold lines on the washer to the 'Y' attached to the cold faucet. You won't be able to wash in warm or hot without changing the hoses, though.
Aug 17, 2011 | Washing Machines
My whirlpool wfs1273bd the door open light is red and the display is showing F08 when i press start
here is what my service manual says for that fault code
F8 Board failure Replace control board (also called ERC or clock).
Hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Kitchen Ranges
No problem but bought washing machine from Casey Auctions but it did'nt come with the manual where do i find it on yhe webb site. WFS1273BD
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 23, 2011 | Washing Machines
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    A Whirlpool Front Loader WFS1273BD. Red light says "Clean Pump". How do I do this?
    there is a pump filter in the bottom front right side get a screw driver pop the cover off unscrew the plug/catcher & clear anything out thats in there and if it still doesnt work the pump has probably failed.
    Jan 15, 2011 | Washing Machines
    Looking for Whirlpool front loader washing machine manual - WFS1273BD
    Try
    searspartsdirect .com
    30 years Experience in Home Refrigerator,Washer,Dryer, A/C Repair
    I would love to help you find a solution.
    Leo Ponder
    Aug 28, 2010 | Washing Machines
    Washing Machines Logo
    211 people viewed this question
    Top Washing Machines Experts
