Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
  • KitchenAid Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 29, 2010
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
catriver
  • 878 Answers
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Posted on Jan 16, 2008
  • 9 Answers
SOURCE: soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Posted on Apr 20, 2009
  • 1632 Answers
SOURCE: wont clean dishes
Oppen it up manually for a few times Vitally
Posted on May 13, 2009
  • 4088 Answers
SOURCE: during dishwasher cycle soap dispenser won't open
Remove the door inner panel and check the dispenser door solenoid for free movement along with the latch mechanism. Water can enter through a leaking seal and corrode the interior of the solenoid causing sluggish or non-functioning of the latch. Change the solenoid if it seems sticky and can't be fixed by cleaning the bore and plunger (don't apply oil as it will gum up the operation after a while).
Posted on Oct 18, 2009
Hey there my soap dispenser will not open up during the wash cycle ?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Oct 26, 2010 | KitchenAid KUDS03FTPA Built-in Dishwasher
The soap dispenser does not open completely during the cycle. We are using pod soap and it is just stluck in the partially open dispenser and the dishes are dirty.
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned. Here is a link to instructions that might help that. But not knowing your specific model these instructions may not apply
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 25, 2010 | KitchenAid Dishwashers
The soap dispenser door does not always open
the dispenser has to be changed. there is a spring that might not be spring back to open . its easier to replace then to get the kit and rebuild your dispenser.
Feb 24, 2010 | Dishwashers
Soap does not dispense from cup.
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser not opening during wash
Most of the time the dispenser unit fails. It has a wax motor syetem and it just fails. Since you have to takethe door apart,I would suggest calling for service.
Good Luck!
Nov 17, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
487 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
