Question about Poulan Garden
I am disabled and can't work on the mower. My wife says she can't get the cutting hight adjusted. I remember it has a knob on the deck to do this. can you possibly help?
Dear Sir,
We are a groundcare machinery co and have been est 30yrs. We have converted a number of machines to suit disabled people such as ride on and tractor mowers.
Maybe we can be of help. 01245362377. Regards, Gavin Wallis.
Posted on Aug 27, 2010
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
How to get mower deck to rise to number 6
will have to adjust delifter rod they have ad just ment on it but when you do this wont be able to cut same hight grass any more
Sep 01, 2014 | Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Need to know how to operate the adjustment knob for the cutting heighth on the deck lift component on a Craftsman MV18S - 58560 riding mower
that model # is for the engine
the knob should screw in or out
pull deck lever up screw knob either in or out release deck lever
Apr 29, 2013 | Craftsman Garden
Replace blde belt on Model # 917.256562 Lawn Tractor, someone please, please tell me how to do it. I was told u could , and not drop deck.
I totally disabled for 6 years. Remove the deck is the only way. It takes me a week or two but finally take it.
Dec 09, 2011 | Garden
Craftsman rider mower 917259567 has a knob for adjusting the mowing height. how does it work, mine seems to be broken
The adjusment knob works only when the mower deck is in the UP, position. You then start by turning the knob CLOCKWISE, if you turn it far enough the mower deck wont go down. You back it off ( COUNTER-CLOCKWISE) to hold the deck in a lower position. Just rember you cant fine tune the heightsetting knob with the weight of the deck resting on the stop (knob), just pick the dech up a little then adjust the knob.
Hope this helps, Matt
Dec 11, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
