Question about Rainbow E series Canister Wet/Dry Vacuum
The belt in our power nozzle is snapped in half. And were going to buy a replacement, but we don't know how to install it. How do you?
  • 694 Answers
The best thing to do is take the machine to an authorized Rainbow dealer and let them replace it.
If your rainbow is still under warranty, replacing th belt yourself will void any warranty there may be.
Posted on Aug 24, 2010
I have a Electrolux Guardian Encore E and the power head quit working. It has suction power head off and all other attachments work.
Try this. Remove the power nozzle from the lower wands. Remove the wands from the hose handle. Snap the power nozzle directly to the hose. Make sure all switches are turned on and try it. If the power nozzle now works, there's an issue with one or both of the wands. If the power head does NOT work, you've secluded the problem to the power head. With that being said and although it could be a power nozzle switch or a wire that disconnected inside, it's most likely the power nozzle Elbow assembly wiring that's worn out. This has been an issue with this model after so many years and you simply need to replace the Elbow assembly.
I hope this helps and let me know if I can be of any more help.
amerivac4u@yahoo.com. Hope this helped. :-)
Apr 02, 2015 | Electrolux Vacuums
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Vacumm Belt keeps coming off.
stick a little bit of tape on the inner half of the spindle, this will put an angle on the belt and should prevent it slipping off.
Dec 23, 2008 | Hoover Vacuums
Hoover Flair S2220 cleaner w/power nozzle disassembly instructions
With the head flipped upside down, take a flat tipped screw driver and carefully pry up the rollers on the front the head. Underneath, you'll find a screw. Remove the screw under each roller, and the front cover will come off with ease. The rollers are just friction fit.
Aug 16, 2008 | Hoover U8185-900 Upright Vacuum
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
Generic problem for all Vacuums
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Where Can I purchase a replacement belt for inside the power nozzle
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=542148
Posted by jdsomerville on Apr 24, 2008
Where Can I purchase a replacement belt for inside the power nozzle?
Not knowing the brand name and model number you can call the phone number listed below and let them know the Brand & Model # to the power nozzle and they can ship you the vacuum belt, or If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Power head hose to fit power nozzle PN-4. Electrolux MDL 1401B
I would advise because this is an older Electrolux Power Nozzle PN-4
Model #1401B that you could buy a replacement hose of which would save you money or you can spend the price for a genuine hose – replacement hoes work just fine and are less money.
www.A-1Vacuum.com 1-800-657-1874 -- they can ship one to you UPS….
Don - The Vac Man
Apr 21, 2008 | Vacuums
Rainbow E series Canister Wet/Dry Vacuum Logo
53 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
