Question about Acoustic Research AW-721 Consumer Headphones
Where can I buy the relacement ear pads for the aw 721? This headset is the best I ever had but the ear pads are somewhat worn down to nothing. Please tell me the price and where to purchase them.
Are there replacement ear pads that will fit on my 2005 Sony headphones ?
There are lots of generic (Chinese) replacement ear pads for Sony on ebay or Amazon, you'll just have to take some measurements and try to match what's available. Check the diameter in centimeters, and the shape (round or oval). You may not find a specific listing for MDR-RF960RK but a lot are interchangeable.
Nov 10, 2014 | Sony MDR-RF960RK Consumer Headset
Where can i get replacement ear cushions for the motorola ht820 bluetooth headset
I have turned my worn-out Motorola HT820 ear pads inside out and have cut off the excess parts of the edges. This worked just fine for me. Obviously the ear pads are not as soft as they used to be, though there're not as thick as well.
Nov 03, 2011 | Motorola Mobility HT820 Wireless / Cable...
How to us a bluetooth headset to pone
  1. Link it to your cell phone. Cell phones can be easy, but nothing is easier than keeping it in your pocket when you talk. Use a Bluetooth headset to have a hands free conversation. They are typically worn over the ear, and can be used without charging for one to four hours.
  2. Use a Bluetooth headset with your PC. You will probably need an adapter to link up your headset with your PC, and they are placed in a vacant USB port in your computer. It enables your PC to communicate with and through the headset.
  3. Pair your Bluetooth headset with your PC in order to use it for VoIP applications. You must set your headset to the discovery option and allow your computer to roam and link with the headset.
  4. Keep it charged. In order to get the most life out of your headset, keep it charged when you aren't using it. This will ensure that it is ready whenever you need it. Use the standard house charger at home, and buy a car charger for traveling.
  5. Adjust the volume. Make it easy on your ears by lowering the volume to a level that is comfortable. When you choose a setting that is too loud you can hurt the ear drum and if you set it too low you may strain to hear the other person.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 03, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
Where can i buy relacement earhooks for the jabra bt135
jabra should have these available as replacements if not i have a couple of my own including a jabra and some of the hook are actually usable between each another headset i hope this help your problem try using a local classified like kijiji or craiglist to attempt to find a dead jabra for parts to use ok
Nov 19, 2010 | Jabra Bluetooth Headset with Adjustable...
I'm looking where to buy sony mdr-rf970r ear pads
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Oct 03, 2010 | Sony MDR-RF970RK Headphones
I broke the plastic ear loop on my bluetooth. I
Depending on the manufacturer, they may not even sell just the loop. Go to their website and see if they list where their products are sold. Check ebay...
Mar 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Sound from only one headphone
I purchased an AW 771 set in "as is" condition which on arrival produced output only from one side. Repair was effected by removing 8 phillips screws, 4 from each side, concealed under the ear-surrounding doughtnut-shaped cushions. To expose those screws, the ear cushions must be pushed from their center toward the outside. Black screws in back holes surrounded by black acoustically-transparent cloth does not make them obvious.
I used a volt-ohm meter to find a discontinuity at a failed solder connection. Resoldered that connection, rechecked electrical continuity to be certain all connections were good. Tested with batteries installed using an audio input. Both sides produced sound. Replaced screws and they have performed very well since then.
I hope this Model AW771 experience is helpful in restoring your AW-721 to working order.
John
Oct 25, 2007 | Acoustic Research AW-721 Consumer...
Acoustic Research AW-721 Consumer Headphones Logo
56 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
