Question about HP LaserJet 2420 Printer
HP 2420dn Event log page lists 49 00FF Printer Error. When first purchased printer connected perfectly with Parallel cable and worked for years. Then connected via USB and no problems. Never installed the JetDirect to connect via network. Moved printer to new location and connected to new pc with USB. PC cannot detect printer, so I am unable to install it. Appreciate your help. Thanks Vanessa
  • mmmagic885 Aug 24, 2010
    Hi Silverdragon
    I appreciate your prompt reply. Apologise for not explaining OS.
    Windows XP Prof SP3
    I have downloaded the file you indicated. It is the same file I used to try to install the printer.
    The file installs ok but the printer is not recognised as a USB only as a Parallel (I have no parallel cables connected).
    I changed the USB cable and I did the same installation on my second desktop, same OS etc.
    I cannot find the DVD that came with the Printer. I will try to purchase one if that will solve the issue.
    I'd appreciate your further advice.
    Thanks again
    Cheers
    Vanessa
  • HP Master
  • 4,737 Answers
Firstly, try it on another Computer, or you can swap/change the usb port (try plugging in on another usb port, i guess at least you've tried this.). If it's not detected even on another computer, then get a new usb cable and try again.
This could be a problem with the usb port on the computer or the usb port on the pirnter or the usb cable itself. Once you try it on another computer, you'll be able to know what's the cause.
Let me know if the problem persists, Good luck.
Thanks for using FixYa.
Posted on Aug 24, 2010
  • HP Master
  • 12,061 Answers
OK what you need to do, is do NOT simply just install the driver, you need to actually use the DVD that came with the unit and install this way, until the proper software is installed, Windows will NOT recognize it. You first need to install the HP software FIRST, then reboot, then it should be detected, and then it will install the driver.
DO NOT plug in the printer, BEFORE installing the software, and ONLY plug in your printer, when asked, OR after you have installed and rebooted.
Please download your software from this website below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412123&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=lj-23079-7
You didn't indicate what OS you are using, IF Vista Win 7, then you MUST obtain an exact driver for that OS, OR install in Compatibility Mode for XP SP2. Also it MUST be done as Administrator. IF a 64Bit system, and you DO NOT have a specific driver written for Win 7 or Vista, 64 bit,you may have to turn OFF Digital Driver Signing, Press F8 at boot up and select from bottom menu. If this is the case, this MUST be done each and every time you use it.
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
I have a HP 4250 Printer. You on power button - it will not print - It only generates a 51.10 error code. What is this error coded telling me and how do I correct it. At present I have had to...
Lets check the hardware first if its working as a stand alone
To test the printer in "standalone" mode, perform the following:
  1. Turn the printer off and unplug any parallel cable from the printer.
  2. Unplug the network cable (if applicable) from the HP Jetdirect card (if equipped) and then remove the card from the formatter.
  3. Power on the printer.
  4. After the printer reaches a Ready status, print the following test pages:
  • Configuration page or Self Test page (list of installed options)
  • Event Log (list of most recent printer events to aid with troubleshooting)
  • Menu Map (lists Printer settings)
Apr 23, 2008 | Office Equipment & Supplies
My HP LaserJet 2420 has disappeared from my "printers" control panel. The printer is connected via USB. I have swapped cables and have tried to install it on another computer with NO result. There are NO...
There might be a problem with your computer as well. Try printing with paralell cable to make sure the interface works at all. If the patalell-port works fine, try updating the printers firmware. Still problems ? Try with a different computer. If if works fine with another computer, then you know theres something wrong with your first computer. Good luck.
Aug 10, 2009 | HP Hewlett Packard LaserJet 2420 Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
Support
49.XXXX
PRINTER ERROR
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
Dec 10, 2008 | HP LaserJet 2420dn Printer
Recently, I purchased a HP Pavilion PC. After setting up the computer I found out that there is not a slot for my printer. My printer is an HP Lazer Jet 3200. Please let me know what I can to so that...
Christopher,
The LaserJet 3200 has 2 different available connections...a parallel cable connection and a USB connection. If you used the parallel connection previously, you will need to purchase a USB cable if your new computer doesn't have a parallel port.
The 2 different connections are shown beginning on page 31 of the user guide.
Here is a link to the user guide if you do not have it:
LaserJet 3200 User Guide
Any questions, just comment back.
Dec 04, 2008 | HP Office Equipment & Supplies
LaserJet 2420dn Error
The error means -
occurred.
Recommended action
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jun 03, 2008 | HP LaserJet 2420dn Printer
Slow printing
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Nov 01, 2007 | Canon BJC 80 InkJet Printer
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
HP LaserJet 2420 Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
