Question about LG 42LC2D 42 in. LCD HDTV
My TV switched itself off last night, however we keep having problems with it not turning on, the red lights fades when I turn it on then brightens again, previously it has done this then after many attempts switches on. My TV is only a week old.
    Sergeant:
  • 192 Answers
Bring it to your vendor and asked for the warranty of repair for it..
Posted on Aug 24, 2010
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
TV turns off by itself after 35 seconds of being on. Indicator light flashes red endlessly.
The TV is going into protection mode. Could be a problem with moisture. Can you try warming up the rear with a hair drier? Ensure that you do not apply too much heat to avoid damage to plastic parts. If you can remove the back cover (after unplugging the power outlet and switching off the TV), try doing in on the entire PCB, if you suspect moisture is the problem. Please do not touch anything in the board by bare hand as there would be high voltage charge in capacitors even after switch off. If it does not work, this might need attention of a qualified service technician
Jul 11, 2012 | LG 42LD450 42 in TV
Watching tv last night, the tv turn off by itself with out touching remote control, after that i keep trying to turn it on and the on/off red tv light startted flashing for a few minutes until it when off...
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Oct 07, 2010 | Samsung LN40A450 LCD TV
Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sony KV-30HS420 turns off all by itself
This is less a solution than a work-around, but it does work for me, and it is free or low-cost.
I have had the same problem on the same Sony (model KV-30HS420),picture fading out to green then black, then turning off by itself,after which sometimes the light blinks 6 times, other times it blinks 7times. This started about four years after I bought it, which is not adecent lifetime for a CRT TV. It would happen anytime from 2 or 3 timesan hour to 30 to 40 times an hour. After getting absolutely nowherewith Sony, which was completely unresponsive and unhelpful, and which refusedto stand by their product or provide any useful information, I wasgetting ready to buy a new LCD TV, any brand but Sony (never buyanything from them again), when on a whim I decided to try one last stopgap solution.
I put a fan up against the side of the TV, blowing into the vents. Ithas been 3 days now, and not once has the fading and shutting downoccurred. So it looks like the fading out and shutting down wassomehow related to heat, and the ventilation seems to have solved it. I don't know why it should be a problem now, when it was not the first fewyears. It is also a mystery why Sony has not been able to figure thisout, since it is clear from online postings that many people have thisproblem with this model. Give this a try and see if it solves theproblem for you.
Apr 07, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
TV WENT OFF BY ITSSELF
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
Power won't stay on
What does the light blink? Also look on the printed circuit boards right below the picture tubes and see if there is any fluid leaking on them. These are the first things we need to know.
Sep 12, 2007 | Hitachi 60UX58B 60" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
80 people viewed this question
Computer Repairing
Computer Repairing
