Question about Epson Stylus CX4800 All-In-One InkJet Printer
How to fix a paper feed error - Epson Stylus CX4800 All-In-One InkJet Printer
    Scholar:
  • 120 Answers
To fix your paper feeder follow the mention tecnique:
1. open your printer paper feeder
2.put off spring
3. Then find out a white roll gide and open it.
4. Open roll gide from the printer. Then open black roll from white case. In the hole a spring apear . put off the spring from there.
5.Finaly assembel all the parts again without the spring.
I think your printer may work again. Thank you.
Posted on Aug 24, 2010
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
Paper jam error
This error apear usaly on this machine , when the cloutch sistem of paper feed roller are obsolete , to fix this issue you must clean the sponge out the clutch or replace-it becouse this is already sticky
Feb 02, 2014 | Kyocera Mita FS 1010 Laser Printer
The paper jam indicator on in error?
So it sounds like the machine is not feeding paper from the paper cassette. This is a common problem.
There are 2 possibilities. 1 easy and one a little tougher. The simple fix is cleaning the paper feed tires. Just pull out the paper cassette, then remove all the paper. You will see 2 felt type pads on the spring loaded metal plate. Spray these 2 pads with some glass cleaner. Dry the metal plate a little then lock the plate down and re-install the cassette without paper! Make sure the lower tray is selected for paper feeding and press the print button. The machine should try to feed a few times then shut down with a P in the display. Reset the P using the clear key then press print again. Repeat this procedure 5 or 6 times. Then remove the tray, dry the pads a bit then re-load the paper, re-install the tray and give it a try. If dirty feed rollers were the cause then this procedure will fix it. Let me know how this works out.
Thank You for using Fixya
Apr 23, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Manual paper feed works but not automatic feed.
I've been told labels have to be manually fed on that printer.
Mar 30, 2010 | Brother HL 2140 Laser Printer
The printer will not feed the paper into the machine
Hmm, this is too general symptom too troubleshoot. But never mind. Printer cannot feed the paper for several reasons:
Auto sheet feeder (paper feeding mechanisme) is faulty;usually generate error message on the monitor or/and error code on LCD display
Paper end did not reach paper sensor because the paper not set properly or another material block the paper path.
To find out more about this error,please check the following article exclusively for Canon printer.
Paper feed error
Paper jam error
Source: Canon Inkjet Forum
Oct 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
When i turn it(canon MP780)on, i see a error (##357). How can i fix it?
The service manual says this for ##357:
ASF paper feed (AP) position error.
AND ALSO:
##357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***’Y.
(3) Replace the SPCNT board.
Apr 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mecha error 07
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
Sep 29, 2008 | Kodak 6800 Thermal Photo Printer
Printing
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
Epson Stylus CX4800 All-In-One InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
