Question about JVC HD-61Z456 Television
I repalced the lamp,however the blue light still blinks and th tv will not turn on.
  • JVC Master
  • 17,130 Answers
The power supply must be checked for any possible damage in the unit. See the power main filter capacitors for fault. If Ok check on the main board, look for short in the main board or a possible dry joints in the convergence IC's. If you find them suspicious change.
Disconnection of the +B should bring up the voltage . Hence the concerned circuit /IC can be centered out.
The microcontroller must switch and cut off in such an error. If blings it still present, possible it needs a reset. Try to press and hold Menu/input while switching power on.-Try the rest code if present in the manual.
Posted on Aug 24, 2010
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
The blue lite comes on and then starts blinking. nothing happens. when I turn off the lamp light comes on. Has a new lamp
whats the model number of the tv? Have you checked the user manual to check to see how to reset the tv after replacing the lamp? Usually there is a sequence to perform after replacing the lamp and most of th etime you have to have the original remote to perform it - i'd check that first..
thanks,
phatcav
Feb 05, 2011 | Hitachi Televison & Video
Tv not turning on
Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
Apr 05, 2010 | Hitachi 60V500 60" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Tv wont come on
You may have a Lamp fan that is not turning. You can verify this shining a flashlight in the Fan Exhaust housing and see if it turns when you turn the set on.
Jul 17, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
Tv doesnt turn on after replacing lamp??
Just took a look at the manual.
This information is in the troubleshooting section of appendix H in the owners manual.
12. Lamp indicator light is a flashing yellow. Lamp cover door is open or lamp cartridge is not secure. See AppendixH for lamp replacement information.
Appendix H is a bunch of graphics. that you'll need to see to understand. i can't paste it all here.
Oct 31, 2008 | Mitsubishi WD62527 62 in. LCD HDTV
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Panasonic PT-53WX42 - When I turn the TV on, the red light comes on but, no sound or picture.
Does the light blink? If it is blinking a 3 code, the IC's need to be replaced. Those three lamps as you called them are not lamps, they are the three picture tubes.
Jan 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
JVC HD-61Z456 Television Logo
461 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
