Question about Husqvarna Sewing Machines
Hello ... I have a Husqvarna 2000 ... from new. I am trying to use the twin needle , and it is gathering like a corded stitch ... too tight. I have the book supplied with the machine , and I can't find how to set the settings to correct this. There are instructions on page 34 of the manual that I have for corned work , but it does not tell me the settings, or the seam former to use just for tin stitch sewing... only the 389 presser foot. I hope you can help with precise instructions. Many thanks ... Margaret R.
  • 109 Answers
I don't know your machine but the twin needles are generic so I will give you a couple of options. First thing to try is turn your upper thread tension down to 3. If that doesn't work try using a wider twin needle. The width goes up to 4.0 and some machines (check your manual) have the ability to use a 6.0 twin needle. If you are using a lightweight fabric you can use a tearaway or light to medium wash away stabilizer on top of the fabric. If using tearaway (like paper) draw your stitching line on it and pin it to your fabric. You only need a strip an inch or two wide and the length of your stitching line. It doesn't have to be all one piece. If you use wash away (like plastic wrap) just dampen each end of the strip and place it over your stitching line and it will stick. When you start sewing it will stay in place and you can tear it off after stitching. It will keep the fabric between your needles flat. The 389 presser foot is made to be used with cording under your fabric so you have a raised look to your stitching rows. I hope this helps. Please email me back if I can be of any more help.
Posted on Sep 13, 2010
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
How do I attach a twin needle post to my Bernina 950
Hello Erina
Sounds like you purchased and wish to use a twin needle which comes as two needles on a single needle shaft, correct? That is terrific and you have a wonderful machine.
Remove the needle in the machine just the same as you have been over the past 2 years. Unscrew the needle clamp screw, pull down on the needle or part of the needle in the machine and insert the new twin needle shaft into the needle bar. Tighten the needle clamp screw and thread the needles using two sources of thread on the top.
If the existing needle post is not coming out of the needle clamp easily, use a pair of pliers to grip and pull down. Cover the sewing surface to ensure that it will not be damaged as the pliers free the needle. If the needle is firmly embeded, you may need to give the pliers a gentle tap with a small hammer.
If using a zig zag stitch make sure that the width does not exceed the twin needle limit; otherwise as the needles swing from side to side they can hit the stitch plate and brake.
Happy Stitching
Oct 23, 2014 | Sewing Machines
Twin needle
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
Jan 30, 2014 | Husqvarna Huskystar 207 Sewing Machine
Thread keeps breaking using husqvarna
try these suggestions
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 30, 2012 | Husqvarna Sewing Machines
When using twin needles only one line of stitching is stitching normally, the other line is jumping stitches. I have tried rethreading & changed the twin needle. With the first twin needle the left...
now that is strange. check your thread, now take that twin needle and try this, shove it very hard up into the the needle holder. my thought is that it is not up enough. because your problem is exactly what would happen should the twin needle be sitting too low. try shoving it up higher and test again.
Aug 26, 2010 | PfaFF Quilt & Craft Pro 7530
I want to be able to hem knit fabric using a twin needle. I always wind up with a hill forming between to two rows of stitching. Is there a way to adjust the bobbin tension to reduce this hill...
Never mess with the bobin tension, just make an adjustment to your stitch length, I suspect the stitch length is set for small stitch, try it on #3
Aug 15, 2010 | Husqvarna Designer I
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
100 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
