Question about MyMusix PD-6030 MP3 Player
Flash error please back up the data and format disk
How do I solve this problem with my MyMusix 6030 MP3 player?
  • jossr May 05, 2008
    I paid my $9.95. Where is my solution?
  • 8,596 Answers
Reformat the player.
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Posted on May 24, 2008
MyMusix PD 6030 persistently displays flash error! please backup the data and format the player. This happened after I tried to replace an existing playlist with a new one.
I would recommend you do back up your files to the computer and then format the player.
Q: How do I format my PD-6030?
A: There are various way to format the PD-6030.
With Windows XP, go to Start, All Programs and select 'My Computer'. Then see if there is a device called an 'Audio Player' listed there. If so , open the Audio Player and right click the item named 'Internal Storage' and select 'Format'. Once the format is complete, unplug the player and turn it on. Once it turns on and says 'No Files' plug it back in to your PC and add the music back to the player.
With older version of Windows, the player will show up under 'My Computer' as a 'Removable Disk'. Right click that and select "format'.
Oct 16, 2009 | MyMusix Audio Players & Recorders
Mp3 player has an error
Can you access the player with Windows?
Apr 27, 2008 | MyMusix PD-6070 MP3 Player
Flash error backup data and format
just connect it to the computer then save all ur folders to ur desktop thats the easy way to back up data
May 15, 2009 | MyMusix PD-6030 MP3 Player
Flash error! please backup the data and format the player
remove the player program, Then reinstall the converter program from the disk first. Then reinstall the primary program, this will ddelete the converter program you just installed. When I did this the Player began to work properly. Why? Any ans I came up with does not make sense. It just happened to solve the problem for me. Hope it does the same for you. Also, doing this you will find ( at least i did) that youare starting from scratch as if it were a new machine.
Dec 26, 2008 | MyMusix PD-6030 MP3 Player
Mymusix mp3 gb1 pd6030
my mp3 quit working, put in new battery and now nothing happens after boot up, blut mymusix and shuts off. what the heck do i do now
Mar 19, 2008 | MyMusix PD-6030 MP3 Player
Flash error message
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check www.mymusix.com for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Mar 11, 2008 | MyMusix PD-6030 MP3 Player
Flash error
same here just a diff mp3 ...
Nov 25, 2007 | MyMusix PD-6030 MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
Flash error - won't let me use player
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Oct 27, 2007 | MyMusix PD-6030 MP3 Player
My Musix MP3 when turned on says flash error please backup the data and format the player. When I put it in the computer no message to tell me how to do this comes up. I don't have the manual anymore. Please advise.
Oct 24, 2007 | MyMusix PD-6070 MP3 Player
MyMusix PD-6030 MP3 Player Logo
48 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
