Question about Kenmore Elite 45986 Front Load Washer
After wash is almost done, it stops and says 09 minutes left and then f
  • Kenmore Master
  • 17,129 Answers
Possible fault in the timer control unit. Please check the washer on different modes particularly on the easy wash mode and see if the fault is occuring. If it is consistant that the timer is running behind then the clock might be out of sync with the processor controller.
Check to see if the motor is free, the capacitor is good because the fault can also occur due to a load shut off. .. spcially if the motor is running slow or the drain pump is faulty shutting an early action.
So check this out.
Posted on Aug 24, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    What is the A:09 code
    Code A09 means there is a problem with the water supply. Ensure your water is turned on completely, unplug the machine for 1 minute and then plug it back in. If the code persists, you should turn off the water and remove the supply lines. There is usually a filter in one end of each hose or at the water valve hookup. Ensure that the filter is clean and replace it. If you have done this and you know that you have good water flow through the supply hoses, I would suspect the water valve solenoid(s) as being defective.
    Dec 22, 2014 | Whirlpool LSR5132PQ Top Load Washer
    Washer will start and then stop 5 seconds later. It will start again 2min later and stop 5 sec after that?
    I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
    Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
    Aug 12, 2011 | Frigidaire Washing Machines
    I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
    i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
    Apr 29, 2010 | Whirlpool WFW8300SW
    I have the CFW-8000 washing machine. When the
    It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
    The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
    It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
    Also sounds like your water or fabric softener is blocked too!
    Take the plastic parts out and clean away all soap residues.
    Nov 18, 2009 | Crosley Washing Machines
    Whirlpool Calypso stops at 26 minutes and throws ob code
    first you need to clean your washer
    run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
    then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
    this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
    May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore (sears) oasis washer stops with 36 minutes left
    The timer is failed.
    Replace it.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Clothes have a musty smell if left in the washer
    Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
    leaving the door "Open" for several hours, when finnished, eliminates any future
    smells.
    Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
    Stops at 19 minutes left and will not do anything
    As a first step, try cleaning the lint filter as per instructions elsewhere on this site.
    Jun 30, 2008 | GE WSXH208A Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    23 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
