JUST CUT OFF. WILL NOT TURN ON EVEN WHEN PLUGS WERE SWITCHED.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
The power supply is the main problem
thank you"
Posted on Aug 24, 2010
I dont want to look at the No HDMI Cable Message after the computer shuts down. Is there a way to make the screen go blank more quickly. Or do I have to watch the message scroll across the screen for 10...
A couple of options. First and cheapest, you could turn off the monitor. Second, for about thirty to fifty dollars, you can pick up an energy saving surge protector. With this, it has a main plug, and switched plugs. The switched plugs cut power when the main item is turned off. I.E. PC turned off, monitor, speakers, printer all turn off a moment later.
Dec 11, 2011 | Dell ST2420L 24 inch LCD Monitor
I CANT GET MY MEMORY TO STAY WHEN I CUT OFF MY CAR I HAVE A 1992 BUICK ROAD MASTER
Most after-market decks are supplied with two separate leads for power. One needs to be connected to a "constantly on" source (such as the car battery) to maintain time, memory presets, etc. The other, is connected to the switched power source if you want the radio to shut off automatically when the key is switched off - or connected to the same constantly on source if you want to be able to turn the radio even without a key. The latter method will require that you manually turn the radio on AND off. If you forget to shut it off, you'll probably find a dead battery the next day.
It sounds as if you have connected both of these wires to the switched power source. You'll need to review the wiring diagram for the radio and make the wiring change to have it work the way you expect. Many times, purchasing the vehicle specific wiring harness
for an aftermarket radio makes this much easier. If you cut the old connectors off 9a16381.gifthe car's wiring harness - it's too late to do that. But if it is still intact, you should be able to find the plug in harness at Best Buy (or similar), any of the many smaller, independent automotive electronics shops, and internet shops like Crutchfield.
Oct 22, 2010 | Pioneer 50W x 4 MOSFET Apple iPod...
I was making a standard cake with my kitchenaid and in the middle of creaming butter and sugar together, it stopped working. Turned it off, switched plugs, let it cool down, etc - it won't turn on now and...
either the electrical motor brushes are worn down on the motors commutator and can no longer contact the motors commutator bands,or if its a newer style mixer the triac that controls the speeds on the unit could have opened up and can no longer supply variable or even high speeds
Aug 01, 2010 | KitchenAid Food Mixers
I have a 90 sunbird it just cut off going down the road,it didn,t jump time,has plenty of fire replaced plugs wires ignition coil fuel injector cap and rotor button even sprayed ether in it can,t even get...
you may want to check your starter/ignition relay switch fuse good possibility that it could b burned out if it wont even turn over now hope this helps
Dec 08, 2009 | 1990 Pontiac Sunbird
How do I stop the spa from starting up and switching the heater on after a power cut?. Pump 1 will run the first time switched on,but if switched on again, it sometimes just stops and wont start for some...
It's not possible to stop the spa from starting up after a power loss. Most spas go through a self test then try to reach the last set temperature. Pump 1 usually runs the filter/heater, once it's activated it should run for 20min or until you turn it off. The high speed on pump 1 should always work. One problem with the pump may be that it's heating up and the internal high limit won't let it turn on. When you shut the pump off, the motor gets even hotter for a period of time since the fan is not turning, it may be getting hot enough to trip the internal high limit so that it won't turn on until the motor cools down. It won't turn on even if the topside control indicated that it should be on.
Dec 01, 2009 | Pool & Spa
Screeching noise
dear friend-the fact that your car did not switch of for 10 sec means that the fuel did not cut when the ignition was switched of.i think you must have it checked.
Jun 24, 2009 | 1997 Hyundai Elantra
Wiring of fog lights on 95 Mustang
If you bought the fog lights from Ford and they plugged into factory plugs at the front bumper, then I suspect you need the headlight switch that came optional for your car. You will need to install a relay into the fuse box. Check for any fuses for that circuit. I did one on a Ford f-150 and the switch came with the lights from Ford.Usually the fog lights are not on until you push a button or turn the switch.
Mar 15, 2009 | 1995 Ford Mustang
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Televison & Video Logo
Top Televison & Video Experts
