Question about Goodman CLQ36AR49 Air Conditioner
We are having issues with our pipes freezing and no air flowing through the vents.
    Problem Solver:
  • 18 Answers
If your evaparator coil is clean and your filter is clean you may have a low refrigernt charge need to get it checked by a service tech. they will have the proper tools to do this.
Posted on Aug 24, 2010
Hi, our outside vent keeps freezing, ant suggestions on this issue? Thanks for your time.
Add a 12" piece of pipe elbowed down if possible. Also make sure the pipe is sloped back to the furnace 1/4" per ft.
Jan 11, 2015 | Heating & Cooling
The pump gets rid of the water in the pan but leaves paper and other deposits behind. I cleaned out the pan but the problem still remains and after about 2 weeks it needs to be cleaned/emptied again. No...
Check the vent pipe, air must flow in and out of the vent pipe at all times. The vent pipe must be an 1 1/2" pipe coming off the top of the pump casing and vented outside the house, to the open air. Do not use a cheater vent, studdor vent or mechanical vents as they are not recommended to be used, they only allow air to flow one way.
Feb 28, 2013 | Saniflo & Saniplus& Macerator Pump
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
Weak vent air
your thermostat is not working properly it should trip off the A.C bt not doing so
Aug 01, 2010 | 2005 Nissan Altima
Macerator overflows
Check the vent pipe, most of the Saniflo products require an 1 1/2" vent pipe vented to the open air for air flow purposes. Air must flow in and out of the vent pipe at all times.
Jun 28, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
I have a saniflo macerator toilet system and when flushed, the pump does not immediately come on and the water level rises up pretty high. only then the pump comes on for a second or two but the bowl does...
Did you put an 1 1/2" vent pipe? It must be vented to the open air. Air must flow in and out of the vent pipe at all times so it can work properly. I had the same issue but after removing the cheater vent from the vent pipe it solved my problem. They do not recommend using an air admittance valve, cheater or mechanical vent on the vent pipe, as it only allows air to flow in or out.
Jun 09, 2010 | Saniflo SANIBEST Pump Macerator Grinder...
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
Oct 04, 2009 | Whirlpool LGR6636 Gas Dryer
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Wont dry clothes is hot inside dryer but takes 3 or 4 cycles to dry load
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Power vent tankless heater has a down draft
I got a dryer vent kit (Alum) took the extension pipe off and cut the center hole open a little and slid it over the existing elbow. Now when the heater turns on the little flap opens and when the air flow stops the flap closes stopping the air coming down the pipe.
Jan 16, 2009 | Rheem Tankless Hot Water Heater...
Goodman CLQ36AR49 Air Conditioner Logo
21 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
