Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does error code LD mean? - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 1,998 Answers
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Posted on Aug 24, 2010
5 Suggested Answers
  • 899 Answers
SOURCE: What does the error code LD mean?
it is taking to Long to Drain
so the pump or hose is clogged
Posted on Oct 18, 2008
  • 299 Answers
SOURCE: What does the code LD mean?
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Posted on Apr 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code of LD
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 23, 2010
SOURCE: I have an error code that says "LD", what does
The LD stands for Long Drain and it flashes when the water level does not change after the drain pump is on. Check to see if the drain hose or drain pump is clogged or is the drain hose situated too high.
Posted on Nov 09, 2010
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
I have a whirlpool washer. model G V W 9959KQ. It is giving me an LD error code.
The LD error code means LONG DRAIN time and usually the reason it displays that code is because something it caught in the drain pump,thusly since something is in the pump its taking a very long time to drain the water.
GENE
Sep 23, 2011 | Washing Machines
Nov 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
446 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
