Question about Minolta 2430DL Color Laser Printer
Minolta 2430 magicolor has fatal error code 18h. what needs to be done? please advise. thanks.
  • Minolta Master
  • 6,161 Answers
Fuser unit replaced, The hot part
Posted on Nov 21, 2015
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Posted on Jan 06, 2008
  • 214 Answers
SOURCE: Minolta Magicolor Fatal Error
17H means, the toner cartridge does not rotate (Incorrect developing
rack rotation)
its very difficult to fix, first thing you can check is a sensor, if you remove a remove a side cover above the paper feed. and clean it.
there is nothing much you can do.
FATAL ERROR CODE 18H /SERVICE CALL 18 FUSER UNIT: Faulty warm-up
detected
probably something wrong with thermistor or fu lamp is proken.
there is no simple fix for those problems. sorry
Posted on Feb 29, 2008
  • 12 Answers
SOURCE: Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Posted on Aug 05, 2008
  • 214 Answers
SOURCE: Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Posted on Sep 17, 2008
  • 44 Answers
SOURCE: konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Posted on Apr 20, 2009
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430DLshowing Fatal o8h
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 12H on Konica Minolta Magicolor 2430DL
This error (12H) pertains to the Laser Unit of the printer which is damaged and needs to be replaced. The Laser Unit is the heart of the printer, it's what transmits the image to be printed. You need to contact a service center and will run you about $200. I had this same problem with my printer and had to call Technical Support and they gave me the bad news
Oct 26, 2008 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error - Code: 2AH
hope it helps
regards
Sep 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
hope it helps
regards
Sep 14, 2008 | Konica Minolta magicolor 2430 DL Laser...
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Minolta 2430DL Color Laser Printer Logo
112 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
