The computer is not receiving electricity because the inlet that the power chord fits into (inside the computer)is wiggly and not getting contact with the chord. Can I send it off to get it fixed? I'm in Alaska for a summer job.
    Genius:
  • 2,785 Answers
Yes you can
Posted on May 05, 2008
What type of power cord is used for a cyberhome dvr 1600 ?
Hello
There is nothing to look onto the power chord of any type of eletronic equipments. Choose a good quality one, with more strands inside its core, that is all. More the strands, the capability of the power chord increases. Look for a good wone which have enough flexiblility to its insulation. Usually MX is the better if you get. IK.
Jan 18, 2011 | Cyberhome DVD Recorder - DVR1600
Power cord broke, where can i get a new one?
Hello
Power chords can be got from the most electronic spare part shops. Go for a good quality power chord. With more strands inside it is better. Keep a piece of power chord as sample with you when you go for it. Take a power chord which comes to the length of 3 yards or so for Tv. You just say the salesman that the chord is for Tv use. Ok
Oct 27, 2010 | Axsion Axion AXN-7200 TV
It will not power up. Fuses are good and transformer is good
you may have a problem withe the power supply circuit. It is the first circuit that is found internally after the power chord if you would trace it from the power chord to the inside. IT may be a damaged capacitor or the entire circuit may have gone bad. Check for swollen capacitors or leaking ones or traces of burn. Damages may also not be visible.
Jul 16, 2010 | Onkyo TX-SV373 Receiver
How do i fit the rotary spit for eb270 built in oven
insert the support frame in the 2nd level from bottom - wiggly bit facing outwards and up. inset grilling tray on bottom level to catch fat. Heat oven, then insert end of rotary spit in hole at the back RH corner of oven (slide cover aside) balance front end on wiggly bit, unscrew handle, close door and press rotary spit key (2nd from Left bottom row)
Jan 16, 2010 | Gaggenau EB 270/271 Electric Single Oven
Hp psc 2210 all-in-one on power up all the lights blink nothing else happens
connect the printer directly to walloutlet.disconnect the power chord from the back of the printer press the on button on the printer for 10 times.then press the power and cancel button simultaneously and keep holding the buttons while with the other hand disconnect the power chord wait for a minute connect the power chord back to the printer .if that does not work then took out all the cartridges clean the electrical contacts on the cartridges also clean the electrical contacts in the printer then put the cartridges back .if that does not resolve the issue try with new set of cartridges.
Sep 13, 2009 | HP PSC 2210 All-In-One InkJet Printer
Computer stopped receiving power and won't turn on.
When you move the hard drive from one computer, it won't boot up unless the both computers are exactly the same model and configuration and with the same installed devices.
Generally you need to install Windows again to get a functioning computer when you transfer a hard disk into another computer.
Jul 29, 2009 | Gateway MX8711 Notebook
Directv DVR Plus R15 Receiver won't power on
sounds like the receiver has gone bad. if you have tried it in numerous rooms/outlets and its not the electrical cord (its plugged in tightly at the back if its detachable) sounds like the receiver needs replaced. if you have the protection plan it MAY be covered under this and MAY be replaced for free. contact directv at 800-531-5000
Feb 15, 2009 | Philips DIRECTV R15
Power supply cable
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Jul 24, 2008 | Toshiba DP80F Printer
Hello, My name is kenny tompkins. i have a problem with my fender bassman amp that no tech in my area can figure out. i was hoping to run this by you and see if you've ever encountered this problem before....
I can't confirm this without testing the amp directly, but I would suspect bad capacitors in the pre-amp section. Some of them may have dried out a bit over time. Anyone that is familiar with guitar amps should be able to resolve this for you. The other thing to check is the 12AX7A tubes inside. Swap them around and see if the symptom changes. You may also have a bad tube.
Keep us posted.
Dan
Jun 27, 2008 | Audio Players & Recorders
MP830 will not power on
Here is what Canon has to say:
Solutions for Printer won't power up Issue: The device does not power on
1. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source 2. Disconnect the power cord and wait approximately 10 minutes 3. Press the ON/OFF button to power on the multifunction device 4. Disconnect and reconnect the electrical cord to ensure a secure connection 5. The MP830 may require repair 6. Try a different electrical source / outlet
Here is a snip of my notes on the same subject for an Epson printer:
Well, first things first I guess:
  1. Try the printer in a different outlet (other side of room, or similar, not same power Jack)
    1. If you have power here, your issue is likely the outlet, not the printer.
  2. If the power cord has an "on" LED, check to see if it is lit up while plugged in.
    1. If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
  3. If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
  4. You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
  5. The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, but I can't tell from the Canon site if this printer has one or not. (It would be a black box between the plug and printer.)
    1. This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
      1. If this is the case you will want to contact Canon if the unit is still under warranty.
-Hope this helps.
May 27, 2008 | Office Equipment & Supplies
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
