Question about Asko D1776 Built-in Dishwasher
It seems like there is not enough pressure to activate the cleaners they barley move,i have watched it while it was open its trying to work
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ?
( it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver )
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko dishwasher and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders fall out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there.
Good luck,
Macmarkus :)
Posted on Aug 24, 2010
There is only enough water to cover the clothes in the washer on the wash cycle, is this normal
Hi Judy, This is quite normal for modern machines. It's an eco friendly thing.
Jul 12, 2015 | Washing Machines
Thanks Terry. The car does not have full power.
Are you getting turbo boost pressure, waste gate may be open check waste gate actuator. Check that BOV is not stuck open you could clean with some throttle body cleaner. http://www.youtube.com/watch?v=govRsNtY8DM
Jun 14, 2015 | Cars & Trucks
My 1995 dodge v10 just quit while running driving it. It started up but would barley run. t would not move. seemed to be starving for fuel. Then quit . The next day the truck started right up and I was...
I once had a 302 ford van that ran really bad going up a hill and I thought the transmission was dying. Turned out that my catylitic converter had broken apart and clogged so the truck wasn't exhausting at all. This will make a vehicle hard start and run bad, so make sure you feel the exhaust for pressure. Seems silly, I know but I've been there.
Nov 10, 2012 | 1995 Dodge Ram 2500
Walnt play cds, it says reading and then no disk, just got it out of the basement, been down there for about 4 or 5 years barley used and idea whats wrong?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jun 30, 2011 | Audio Players & Recorders
My Polaris 3900 that I bought today is not moving fast enough. There is no blue restrictor cap in the wall.
Check your filter, pump, and debris baskets for excessive waste that could decrease the pool cleaners water flow. Check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. Check your wheel RPM. If it is below 30, you will need to incease the water pressure. If you have an adjustable return valve, make sure it is open all the way. Also, make sure that your pump is working properly.
May 28, 2011 | Polaris 3900 Sport Pool Cleaner ()
Hayward Navigator just had shoes and wings replaced. Everything seems to be working but moves extremely slow, even when suction is increased.
Did you have the turbine and A-Frame inspected or the gear box at the back of the cleaner looked at? Hayward Navigators are 100% repairable and most every pool store carries every single part to make the repairs. If these parts are also worn down, you will notice performance issues with your cleaner.
Before we assume the worst, lets run the cleaner through a few inspections.
Simple Troubleshooting for your Hayward Navigator When It Is Not Moving
The most common reason the Hayward Navigator stops moving is there is something blocking the mouth of the cleaner. Pull the cleaner out of the water while the equipment is turned off and make sure the cleaner is not clogged with debris or plugged with a pool toy. Also, make sure that all the internal components are properly installed.
Not Enough Suction - Next, verify that there is enough suction to allow the cleaner to work properly. While the pool equipment is on, lift the Hayward Navigator to just below the surface of the water and feel to see if there is a reasonable amount of suction getting to the cleaner. If there doesn't seem to be enough pressure, make sure all baskets are clear of debris, the main pool filter is clean, and that the diverter valve is open to the pool cleaner.
Small Debris Inside the Navigator - If there seems to be enough suction getting to the Navigator, but the pods are not moving back and forth, there is probably some small debris inside the cleaner that is stopping the turbine from moving. In order to remove any debris from inside the cleaner, remove the small access cover from the bottom of the cleaner by loosening the one screw until the plate pulls off. Use your fingers or the hose to clean the inside of the cleaner out.
If following these simple troubleshooting tips doesn't correct your cleaner issue, there is probably a mechanical issue. Take your cleaner into a local swimming pool retailer or have a service company out to assist (though most pool stores will not ever charge you for labor to make repairs!)
Thank you for posting your question on Fix Ya! I hope to have been of some help to you regarding this issue and if you need some additional clarification, please feel free to let me know what happened with your cleaner! We also appreciate your feedback in letting the world know if you were satisfied with our help!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward Navigator Pool Cleaner
Wheels are not turning. water is spraying from back up valve continually so not enough pressure to put machine into action
If the pool cleaner is not running properly (too slowly or not at all), you will want to check the following things. Make sure that your wheel RPM is not less than 30. If it is, you will need to adjust the wheel RPM to make the cleaner have enough power to move properly. First check your filter screen and the debris baskets in your pump, filter, and skimmer. They could have a blockage that is causing the loss of power. Next, if you have an adjustable valve on the cleaner line, open it completely so water can flow freely to the cleaner. If that does not work, remove the blue restrictor disk from the UWF. Also, check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. If you think that it is simply your backup valve that is malfunctioning, you might need to replace it. The backup valve kit is part number G52.
Jun 12, 2010 | Polaris 3900 Sport Pool Cleaner ()
My whirlpool does not work in the spin cycle
Check the spin cycle activation switch located on the lip of the machines casing where the lid comes down to close.
Often the switch that activates the cycle either goes out and simply needs replaced. Or has worked loose from it's bracing and when the lip comes down to make contact { push it in } the switch body shifts and doesn't receive enough pressure to activate the cycle.
Replacing the switch is both easy and inexpensive if you replace it yourself and avoid a tech service call that would generally cost more than the part itself.
Jul 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The booster pump is running but low pressure
this could be two problems first is pump basket filled to top with water if not you have a air leak check all connections the other is filter is dirty especially de filter backwash hope it helps
Jul 08, 2009 | Hayward Pool & Spa
Asko D1776 Built-in Dishwasher Logo
389 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
