Question about Emerson LC320EM9 32 in. LCD HDTV
Emerson lc320emx and macbook pro are not compatible through a MiniDisplay port to DVI, DVI to HDMI. Basically the HDMIis telling me that the format is not supported although the cable worked perfectly for the first 12 hours I had it, I am confused and frustrated, I want to be able to watch things from my laptop to my emerson, please help! Email: Greenplastiqtree@gmail.com, Brooke Razo
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Remote control code for dish network for Emerson
Your Dish remote was probably designed years before the Emerson set and may never have codes for it.
However, you can try the followng brands from the Dish code list to see if you can get some basic functionality:
Funai, Symphonic, Sylvania, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
All of the above are manufactured by Funai - the least and lowest of the Japanese electronics firms.
Posted on Sep 07, 2009
fosg2000
  • 229 Answers
SOURCE: hookup pc to emerson tv
those models dont have video input for PC (video port), but if you computer has HDMI ouput you can use that one
Posted on Aug 12, 2010
  • 8457 Answers
SOURCE: my Emerson LC320EMX tv wont
Check ur power out source?If tv have no power LED light indication on the tv bazel frame at all.Tv power LED light indication on the tv bazel are flashing.Tries tv unplug,replug it back like about an hour later for tv to do a resetting itself back to the factory setting.Tv should be working again.If still have the same result.The tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 21, 2011
How can I get the best HD (cable) signal to my old HD TV with no HDMI port. The TV only has Component Video, S-Video, RGB input, and of course Coax input. The TV is an LG DLP TV.
If it is an hd compatible tv the is has to have either an hdmi port or a dvi port. Our old projection tv was hd but before the current hdmi format so we had to use an hdmi to dvi conversion cable. If it doesn't have either of these then it probably isn't hd compatible.
Nov 15, 2017 | LG Televison & Video
Tip
Connect you HDTV to your Mac.
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV Port For best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection. If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference. Mac Pro, MacBook Pro, Mac Mini Mac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports. If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac. If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine. iMac, MacBook iMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection. Make the Connection Once you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV. Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac. Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV. Over or Underscan You may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan. You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV. Time to Watch a Movie Once you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
on Feb 22, 2010 | Computers & Internet
Recognize macbook connect
You may need to check the settings of your mac book that permits you to output the signal to an external display. Also you may need to purchase a display port adapter (VGA, HDMI or DVI) that is compatible with the input connector on the projector
Dec 18, 2013 | Dell 2300MP Multimedia Projector
I connected my Mid 2009 Macbook Pro to my Sanyo DP42746 Sanyo with a minidisplay port to HDMI adaptor. My Macbook doesn't support sound through the minidisplay port. The TV owner's manual suggests...
It may have something to do with the settings under audio output devices. See if you have options, and ensure that the headphone jack (I assume that's what you're using) is set as the default sound device.
Oct 24, 2013 | Sanyo DP42746 42 in. Plasma Television
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
Mar 12, 2010 | Apple MacBook Pro Notebook
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
How do I connect my macbook pro to a Pioneer Elite HDTV?
Newegg.com carries a mini-dvi to hdmi cable that
Item#:N82E16812200375 it's listed as "StarTech MDVIHDMIMF Mini DVI to HDMI Video Cable Adapter for Macbooks and iMacs"This should hook directly into one of your HDMI connectors on your HDTV.
Hope that helps
Oct 31, 2009 | Apple MacBook Pro Laptop Computer with...
Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
Jun 23, 2009 | Sony HT-CT100 Theater System
Emerson LC320EM9 32 in. LCD HDTV Logo
167 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
