Question about Roper RAS8445KQ Top Load Washer
After the first cycle the washer hangs up on the first spin cycle. During this time it makes a hum but does not progress forward. You can move the control dial to the last spin cycle and it will continue. The model number is Stylemaster 4213575 D Thank you...
  • Roper Master
  • 17,130 Answers
Please check iff the motor speed is good enough. If slow check on the capacitor and replace the capacitor.
If this wont improve then the controller unit is a possible suspect.
Make a diagonistic check on these two sections and the possible answer migh help.
Posted on Aug 24, 2010
Washer will not operate properly with full load--decrease load and will spin
Hello sismurphy1 - Does the washer make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Feb 07, 2013 | Frigidaire ATF6000ES Front Load Washer
Affinity washer stuck on spin cycle will not spin
Hi Leslie Barnes - Is the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
Jan 04, 2013 | Frigidaire Affinity ATF7000EG
Will not spin
Hello - Is the drain pump making a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire FEX831CS Top Load Stacked...
Washer does not go into spin cycle
Hello Michael Callegri - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. Try setting the cycle to spin only and verify if water pumps out. If it does not, then the unit could possibly be experiencing an issue with a faulty pump, timer, door lock assembly or control board. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
Nov 12, 2012 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Roper RAS8445KQ Top Load Washer Logo
191 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
