The oven has stoped working completely. Stove top does not work, nor does the oven or Broiler. The only thing that works is the clock, light and electric
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
Top broiler element works sometimes but not often
Sounds like an iffy clock control. You could try replacing it, but it ain't cheap.
May 21, 2010 | Whirlpool RF364 Electric Kitchen Range
Kenmore oven won't get hot
hi,,
check the following
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
thank u
rate me
Jul 22, 2009 | Kenmore Kitchen Ranges
My stove top works, broiler and clock work, but oven button will not come on.
Make sure the clock is set for MANUAL oven if so equipped.
If not the manual oven set, probably a bad bake element.
Jul 06, 2009 | Frigidaire Ovens
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven doesn't light
you should check your fuses located in the top of your stove
Feb 16, 2008 | GE JGBP24 Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
